kuanfly 发表于 2015-1-14 14:49:31
直播组装wasp280穿越机架
wasp280机架优于它的框架组合结构结实,所需螺丝少,以及采用优质纯碳纤维板切割,强度高重量轻,线条优美,空间阔,逐渐地开始流行于穿越界,今天我的机架也到了,装机,直播!
这不是5imx,可以广告吧?好东西得让大家知道呀。
http://item.taobao.com/item.htm?spm=a1z10.5-c.w4002-2742281239.30.BBHplx&id=43132167708
http://cdn.mx3g.com/data/attachment/forum/201501/09/081827ei6vtlmu9wmclmla.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081824g5koc8fxchnxv2zv.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081753do5fz6a5ssjofbsa.jpg
开始:
第一步,拿到所有切割组件后首先组好机身,也就是有弧度的那两块板和电池板、图传安装板、摄像头板和长方形的卡板,如图
http://cdn.mx3g.com/data/attachment/forum/201501/09/081640eh6bylbfvaogq4fb.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081642fpneec4d9hfbjipz.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081648s3gihikx33n6ellg.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081645b6inl6ncc6knjb5l.jpg
第二步,在机身上板安装好飞控,如图提示为机头方向。注意区分上下板。
http://cdn.mx3g.com/data/attachment/forum/201501/09/081650xf7ao6ixgid6b11k.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/08165307o5wf6q3bdk6c57.jpg
第三步,组合弧形机身与上板,上板卡口卡上机身,后端注意上螺丝。
http://cdn.mx3g.com/data/attachment/forum/201501/09/081656zy6bzk0qf4bqk6j9.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081658eiu4azppbwb4po4w.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/0817026i5xbrax9zeaq66d.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081704mebrwbsc25r08mxf.jpg
第四步,组合极臂。需要上螺丝,详情看图就很清晰了。
http://cdn.mx3g.com/data/attachment/forum/201501/09/0817086vnd9jkyznng9kjg.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081710n0ksak0y0mo4znmq.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081713n3m101alziabc60n.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081716wo4e4b69cnwbmjoo.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/08171984p8rjp880178top.jpg
第五步,焊接电调。本人使用主流的某燕1806电机和12安电调,装机多部得到点小经验,与大家分享。黑色子 dan头为1、3号电机顺时针转(反转);红色子 dan头为2、4号电机逆时针转(正转)。
电机的出线是有严格顺序的,把黑色电机如图倒置,排好三相线的顺序,把电调mos管那面向上(mos管面是整齐排列的小方块),此时电调的三相线跟电机三相线依次焊接后,电机转向就正确了。(此法仅适用于这套设备,其他设备不一定适用)
http://cdn.mx3g.com/data/attachment/forum/201501/09/081731ko87u781o3i1s7af.jpg
红色电机的则把电调BEC那面向上放(BEC是图中左下方很突出的方块),三相线依次与电机三相线焊接即可。
http://cdn.mx3g.com/data/attachment/forum/201501/09/081722j6bkklkskb6bho8z.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081726lxfl3d3ff1yetptd.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081729r66qippsi6xrfxgz.jpg
第六步,焊接好所以电机电调后就可以把电机固定好了。
http://cdn.mx3g.com/data/attachment/forum/201501/09/0817332klkdrxqzhseqelx.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081736qzq5eyd8etes5dsu.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081739isvo44dquzbsuvvy.jpghttp://cdn.mx3g.com/data/attachment/forum/201501/09/081742n5swoa5vazvwq5wu.jpg
第七步,接下来就是把极臂依次装上,合上下板,注意上下板间还有两块卡板需要装上并上螺丝。这步比较艰难,努力合上下板后要把电调供电线从侧面弄到机身外。
http://cdn.mx3g.com/data/attachment/forum/201501/09/081747rp0dp80jtvoayr2r.jpg
最后把四个电调正负极分正反扭在一起焊在T头上,机架就组装好了。接着就是上其他设备了。我已经预留了一个JST头以供后续设备接电了。
http://cdn.mx3g.com/data/attachment/forum/201501/09/081750m13zmyac3a13m0p0.jpg
http://cdn.mx3g.com/data/attachment/forum/201501/09/081757ewxp92awhmjpyei9.jpg
long13198 发表于 2015-1-14 15:39:43
tianwaifeixian 发表于 2015-1-14 15:52:40
好帖,支持下~
疯狂活塞 发表于 2015-1-15 16:44:48
moye 发表于 2015-1-19 19:40:28
fly768 发表于 2015-1-21 04:08:20
司马英 发表于 2015-1-21 12:37:03
解放CA10 发表于 2015-1-23 01:48:59
好贴,必须顶!
只是貌似又是一款坑摄像头的机架,若是正面撞击,摄像头必损无疑!
查看完整版本: 直播组装wasp280穿越机架
