【大力电子】Spektrum DX3C遥控器
Spektrum推出DX3C遥控器,这是Spektrum新一代的入门级遥控设备,三通道,20组模型记忆,全新设计的外观,LCD也进行了升级,带有SD卡,可对遥控器进行软件升级,只需安装4颗AA电池,配对接收机型号为SR300 DSM,DX3C的功能较为丰富,还带有一组可编程的通道输出。http://www.redrc.net/wp-content/uploads/2011/03/SpektrumDX3C-2.jpg
Features
- Pre-set Steer Mix. For vehicles with 4-way steering, allows crab steering and 4-way steering.
- 20 Model memory
- 3 Channels: Steering, throttle, and an auxiliary channel allowing the transmitter to be used in almost any surface application
- 1 programmable mix allows any two channels to be mixed together. Allows for 4 way steering, dual brake servos, etc
- Adjustable steering wheel tension allows customisation of the tension to the drivers preference
- Choose the auxiliary channel setting right for the application; 2p, 3p, or linear Servo travel adjust
- Digital trim allows for precise trim adjustments
- Rolling selector for fast and intuitive programming of the transmitter.
- Steering rate adjustment
- Exponential allows customisation of the servo movement/speed to fit driving styles
- 3-5 character model names. Name models to a name that will be remembered, instead of just a number
- Up and down timers keep track of run time.
- Servo reversing allows the direction of servo travel to be changed to make installation easier
- Model copy for easy transfer of model settings between models
- Model reset to quickly erase model settings
- Sub trim to adjust the servo centre position to optimise installation
- Interchangeable rubber grips provide a comfortable fit for the hand.
- Multiple sizes are available.
http://img.rcfans.com/portal/201103/18/152912e9r4rr4rxn0lxx1i.jpg
Source: Horizon Hobby UK
:dizzy: 巡天兽学习了 山人帮顶 沈淼章希望我们成为朋友
