713查看 | 5回复
【大力电子】Spektrum DX3C遥控器
发表于 2014-4-12 09:57:30 | 显示全部楼层 |阅读模式
Spektrum推出DX3C遥控器,这是Spektrum新一代的入门级遥控设备,三通道,20组模型记忆,全新设计的外观,LCD也进行了升级,带有SD卡,可对遥控器进行软件升级,只需安装4颗AA电池,配对接收机型号为SR300 DSM,DX3C的功能较为丰富,还带有一组可编程的通道输出。
【大力电子】Spektrum DX3C遥控器 模型,电池,遥控器,接收机 作者:沈淼章 5537
Features
- Pre-set Steer Mix. For vehicles with 4-way steering, allows crab steering and 4-way steering.
- 20 Model memory
- 3 Channels: Steering, throttle, and an auxiliary channel allowing the transmitter to be used in almost any surface application
- 1 programmable mix allows any two channels to be mixed together. Allows for 4 way steering, dual brake servos, etc
- Adjustable steering wheel tension allows customisation of the tension to the drivers preference
- Choose the auxiliary channel setting right for the application; 2p, 3p, or linear Servo travel adjust
- Digital trim allows for precise trim adjustments
- Rolling selector for fast and intuitive programming of the transmitter.
- Steering rate adjustment
- Exponential allows customisation of the servo movement/speed to fit driving styles
- 3-5 character model names. Name models to a name that will be remembered, instead of just a number
- Up and down timers keep track of run time.
- Servo reversing allows the direction of servo travel to be changed to make installation easier
- Model copy for easy transfer of model settings between models
- Model reset to quickly erase model settings
- Sub trim to adjust the servo centre position to optimise installation
- Interchangeable rubber grips provide a comfortable fit for the hand.
- Multiple sizes are available.
【大力电子】Spektrum DX3C遥控器 模型,电池,遥控器,接收机 作者:沈淼章 9823
Source: [size=1em]Horizon Hobby UK
[horizonhobby.co.uk]
发表于 2014-4-12 21:54:28 | 显示全部楼层
:dizzy:
装甲运兵车 该用户已被删除
发表于 2014-4-12 21:54:45 | 显示全部楼层
发表于 2014-4-13 16:12:46 | 显示全部楼层
巡天兽学习了
发表于 2014-4-14 10:12:07 | 显示全部楼层
山人帮顶
发表于 2014-4-15 01:11:20 | 显示全部楼层
沈淼章希望我们成为朋友
