恒力电机测试,2312 bm1300 电机
今天试试国产的恒力电机怎么样快递几天前就送到了,就是家里人没告诉我,我在刚好在抽屉里找微型电子称时找到的,激动啊!!!!
撕开快递包装袋
http://www.5irc.com/data/attachment/forum/201403/01/1126225zs3zckxc8igic5c.jpg
http://www.5irc.com/data/attachment/forum/201403/01/112657xhfzj00czn7nnv7v.jpg
拆开,发现只有2块泡沫板......有点小失望
http://www.5irc.com/data/attachment/forum/201403/01/11272222n2q0ngnczaawnb.jpg
配件+电机
http://www.5irc.com/data/attachment/forum/201403/01/112742jk4ktii4k820iqh2.jpg
看看那奇葩的尾部,用螺丝加橡胶垫弄成的,拆开很方便
http://www.5irc.com/data/attachment/forum/201403/01/112937z7026g2p8n6jcdj4.jpghttp://www.5irc.com/data/attachment/forum/201403/01/112849r8au39d7egk9zell.jpghttp://www.5irc.com/data/attachment/forum/201403/01/1128147jodpjrp5ruuvr5p.jpg
看看重量,58g
http://www.5irc.com/data/attachment/forum/201403/01/112955cjcj10961psezwb2.jpg
主要配件显示7g
http://www.5irc.com/data/attachment/forum/201403/01/113016fp1a1pe6hfp0z1pv.jpg
螺丝0g
http://www.5irc.com/data/attachment/forum/201403/01/113037vgknspmcks6nmcmc.jpg
配件加电机65g
http://www.5irc.com/data/attachment/forum/201403/01/113055dpfp85do3o5a087q.jpg
这个东东不知道是什么东西,给他称一下吧
http://www.5irc.com/data/attachment/forum/201403/01/1131130210t5ijtl0vj015.jpg
全部配件8g
http://www.5irc.com/data/attachment/forum/201403/01/113131kjj4163jee457jp5.jpg
拆电机,很方便
http://www.5irc.com/data/attachment/forum/201403/01/113212ha98ffpvfa7qak3h.jpg
http://www.5irc.com/data/attachment/forum/201403/01/113243h6tvttzjbpfjdizg.jpg
跟dys电机2830(2212) 1300kv电机进行对比,貌似比它大点
http://www.5irc.com/data/attachment/forum/201403/01/113305wjplaj9wje9e2ja5.jpg
http://www.5irc.com/data/attachment/forum/201403/01/113333wsam6ncvagne3kcm.jpg
跟朗宇2212 980kv电机进行对比,也差不多
http://www.5irc.com/data/attachment/forum/201403/01/113402x2ivfli2s2i99uel.jpg
朗宇的绕线
http://www.5irc.com/data/attachment/forum/201403/01/113432pbama1qapdg5qc5a.jpg
2个电机的对比,黑色的是恒力的,紫色的是朗宇的,恒力的绕线比朗宇的好多了
http://www.5irc.com/data/attachment/forum/201403/01/11350323j2mx22pmuqhmlz.jpg
看那神奇又奇葩的卡簧(在电机外转子的最上面),并且发现了一个小毛病,里面的机米螺丝好像没有了
http://www.5irc.com/data/attachment/forum/201403/01/1135281mimglm3h1oflxuf.jpg
进行推力测试
1.配置:
电机 恒力2312 mb1300 电机
电调天行者40a
电池 酷点 2200mah 11.1v 25c
螺旋桨 皓业1047
推力没测 半油门20秒 下来 电机发热严重,此电机不适合10寸桨,并且电机的声音叫得很大,但解下桨后电机叫声并不大, 震动很小,动平衡做得很好
http://www.5irc.com/data/attachment/forum/201403/01/113623stsjrgwjw17rdz6t.jpghttp://www.5irc.com/data/attachment/forum/201403/01/113557m7exg04exvvnre9y.jpg
2.配置
电机 恒力2312 mb1300 电机
电调天行者40a
螺旋桨 xxd9寸桨
推力测试视频:
http://v.youku.com/v_show/id_XNjc5MjYxNjMy.html
推力:半油门大约为550g左右 全油900g左右(又一次我吧油门微调调到最高,全油门为1000g左右)
http://www.5irc.com/data/attachment/forum/201403/01/1138347v4z7xft33jq71x1.jpghttp://www.5irc.com/data/attachment/forum/201403/01/113809crooav91u0zoqqex.jpghttp://www.5irc.com/data/attachment/forum/201403/01/113744oqkkhx057ww5wwka.jpghttp://www.5irc.com/data/attachment/forum/201403/01/113717ptg53tetjb5eft5j.jpg
3.配置
电机 恒力2312 mb1300 电机
电调天行者40a
螺旋桨 仿apc 9x6桨
推力测试视频
http://v.youku.com/v_show/id_XNjc5MjYwNDgw.html
推力:半油门约为620左右全油约为950g左右
http://www.5irc.com/data/attachment/forum/201403/01/113902kzxrrzg291rx52vz.jpg
先装在小赛上试试玩玩
http://www.5irc.com/data/attachment/forum/201403/01/113929t5ok6mzm33s6zifl.jpg
小赛有点重,因为电池我加大了,推力接近1:1
http://www.5irc.com/data/attachment/forum/201403/01/113949xgg9yhjlikvpmlmu.jpg
http://www.5irc.com/data/attachment/forum/201403/01/113152zgb2m36xb8wlxza9.jpg
http://www.5irc.com/data/attachment/forum/201403/01/113649nnb5mnybm49cz95o.jpg
我拿到的是2316 应该可以用 10寸浆吧? 1047
来自安卓客户端 cisforcer 发表于 2014-3-1 17:55 static/image/common/back.gif
来自安卓客户端
可以,2316相对来说,劲大 kv 是1250的
来自安卓客户端 {:1_1:}{:1_1:}{:1_1:} 不错不错 元芳你怎么看?
