6552查看 | 21回复
搬运一个APM 日志分析软件,直观方便、感觉不错!
发表于 2017-6-30 21:52:28 | 显示全部楼层 |阅读模式
前几天在国外网站看到一个apm日志分析软件,自动化分析,可以提示出存在的问题、列出关键图表,个人感觉不错,搬运给大家,希望大家试用讨论,谢谢!
搬运一个APM 日志分析软件,直观方便、感觉不错! APM,GPS,直观是啥意思,什么是直观,直观的方式 作者:new0618 3907
自动分析文字结果案例:
APM Log File Analiser v2.2.2.1
Log FileName: D:\1\2017-06-25 09-51-43.log
Ardu Version: V3.2.1 Build: (36b405fb)
    Ardu Type: APM:Copter
   FC Version: 0
FC Frequency: 100Hz
   Frame Type: X
Data Found in APM Log File:-
GPS, CTUN, PM, CURR, MSG, ATUN, ATDE, ATT, MODE, EV, DU32, RCIN
Data NOT Found in APM Log File:-
IMU, NTUN, MOT, OF, MAG, CMD, INAV, STRT, D16, DU16, D32, DFLT, PID, CAM, ERR, GPS2, IMU2, IMU3, MAG2, MAG3, AHR2, EKF1, EKF2, EKF3, EKF4, TERR, UBX1, UBX2, RCOU, BARO, POWR, RAD, SIM
FAILSAFE SETTINGS:
  Main Battery = Not Activated
Ground Control = Not Activated
      Receiver = Activated at 975 PWM with always RTL
     GEO Fence = Not Activated
PARAMETER ISSUES:-
TUNE = 0
Information: CH6 Tuning is Disabled
06/01/1980 - 000340: Mode Changed to AltHold
06/01/1980 - 000340: Mode Initialised at 0 0 Alt: 0 Spd:0
06/01/1980 - 000341: Armed
Limited Data Available - Mode Ignored
06/01/1980 - 000342: Mode Changed to AltHold
06/01/1980 - 000342: Mode Initialised at 0 0 Alt: 0 Spd:0
25/06/2017 01:51:59 - 000346: Take Off
25/06/2017 01:51:59 - 000346: Mode Time Changed to 25/06/2017 01:51:59
25/06/2017 01:52:01 - 000372: APM Information: Home is Set
25/06/2017 01:52:01 - 000372: Simple Mode is On
25/06/2017 01:52:01 - 000372: APM Information: RC Pre-Arm checks have been completed.
25/06/2017 01:52:01 - 000372: APM Information: All Pre-Arm checks have been completed.
25/06/2017 01:52:01 - 000372: APM Information: USB is NOT Connected.
25/06/2017 01:52:01 - 000372: Rx Information: CH7 Switch is Low.
25/06/2017 01:52:01 - 000372: Rx Information: CH7 function: Enable / Disable Auto Tune
25/06/2017 01:52:01 - 000372: Rx Information: CH8 Switch is High.
25/06/2017 01:52:01 - 000372: Rx Information: CH8 function: Change to Simple Mode
25/06/2017 01:52:06 - 000558: Auto Mode is waiting for Throttle.
       Alt(m ~ ft)   Spd(m/s ~ mph)   Dist(km ~ mi)     Launch(m ~ ft)    GPS-Sats   GPS-Hdop    Eff(mA/min)
Max      0 ~ 0           0 ~ 0         0.00 ~ 0.00       0.00 ~ 0.00        18        1.21           N/A
Avg      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A         18        1.21           ~~~
Min      0 ~ 0           0 ~ 0          N/A ~ N/A        0.00 ~ 0.00        18        1.21           N/A
AltHold Flight Time (Session)= 10 seconds, 0:10
AltHold Flight Time   (Total)= 10 seconds, 0:10
25/06/2017 01:52:09 - 000684: Mode Changed to Stabilize
25/06/2017 01:52:09 - 000684: Mode Initialised at 34.2085606 117.2646061 Alt: -0.09 Spd:0
Max      2 ~ 6           2 ~ 4         0.00 ~ 0.00       3.89 ~ 12.77       18        1.21           N/A
Stabilize Flight Time (Session)= 7 seconds, 0:07
Stabilize Flight Time   (Total)= 7 seconds, 0:07
25/06/2017 01:52:17 - 000973: Mode Changed to AltHold
25/06/2017 01:52:17 - 000973: Mode Initialised at 34.2085291 117.2645877 Alt: 1.89 Spd:1.78
Max      6 ~ 19          4 ~ 8         0.05 ~ 0.03      14.41 ~ 47.29       18        1.21           N/A
Avg      3 ~ 9           1 ~ 2          N/A ~ N/A         N/A ~ N/A         18        1.21           ~~~
Min      1 ~ 3           0 ~ 0          N/A ~ N/A        4.23 ~ 13.89       18         1.2           N/A
AltHold Flight Time (Session)= 45 seconds, 0:45
AltHold Flight Time   (Total)= 55 seconds, 0:55
25/06/2017 01:53:03 - 002669: Mode Changed to AutoTune
25/06/2017 01:53:03 - 002669: Mode Initialised at 34.2085759 117.2646581 Alt: 4.18 Spd:0.36
25/06/2017 01:53:03 - 002670: AUTOTUNE_INITIALISED
25/06/2017 01:53:03 - 002678: Rx Information: CH7 Switch is High.
25/06/2017 01:53:03 - 002678: Rx Information: CH7 function: Enable / Disable Auto Tune
25/06/2017 01:53:56 - 005231: AUTOTUNE_REACHED_LIMIT
25/06/2017 01:56:57 - 013219: AUTOTUNE_REACHED_LIMIT
25/06/2017 01:57:42 - 015448: AUTOTUNE_SUCCESS
25/06/2017 01:59:51 - 020244: LAND_COMPLETE_MAYBE
25/06/2017 01:59:52 - 020274: Landed
Max      7 ~ 22         12 ~ 26        0.99 ~ 0.61     115.24 ~ 378.08      19        1.37           N/A
Avg      4 ~ 13          2 ~ 4          N/A ~ N/A         N/A ~ N/A         18        1.10          5.13
Min     -1 ~ -4          0 ~ 0          N/A ~ N/A        0.65 ~ 2.14        17        1.08           N/A
AutoTune Flight Time (Session)= 409 seconds, 6:49
AutoTune Flight Time   (Total)= 409 seconds, 6:49
WARNING: DataLog File Truncation Issue Found
WARNING: This is an issue within the ArduCopter Firmware, APM Log Analyser has handled the issue.
Overall Flight Summary:
Max     32 ~ 104        12 ~ 26        1.04 ~ 0.65     115.24 ~ 378.08      19        1.37
Avg      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A         18        1.12
Min      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A         18        1.08
Flight Controller Performance Summary:
          Freq(Hz)     LongLoops(%)   LongLoop(ms)    Analyser Evaluation
Avg         100           1.91            11.03                    Normal
Information: Non-Default HW Frequency detected, Analyser Evaluation may be effected.
Power Summary:
       Battery(V)        Vcc(V)        Current(A)        Cap(mAh)        Used Cap(mAh)    Eff(mA/mim)    Max Fly 80%(mins)
Max       12.05           5.01             0.67             2200               39             N/A              N/A
Avg        0.00           0.00             0.29              N/A              N/A            4.95           355:46
Min        9.15           4.71             0.01             2161              N/A             N/A              N/A
  Overall Flight Time = 473 seconds, 7:53
Max Flight Time @ 80% = 21346 seconds, 355:46
                        Max Flight Time calculation can be influenced by
                         -- Battery Capacity Parameter setting
                         -- Calibration of the Battery Current Monitoring Circuit
                         -- The type of flight being analysed
*** Vibration Analysis has been removed from v2.2 onwards, you should now
*** review the "Vibration Graph" instead to understand your levels of vibration.
软件介绍链接:https://www.rcgroups.com/forums/showthread.php?2151318-APM-Log-Analyser
软件下载:
win7
https://www.rcgroups.com/forums/showatt.php?attachmentid=8543312&d=1451130192
xp
https://www.rcgroups.com/forums/showatt.php?attachmentid=8543313&d=1451130228
下面下载是另外两个,也可以试试。
APMLogVisualizer1.3.zip
33.69 KB, 下载次数: 45, 下载积分: 牛币 -10
APMLogBrowserSetup.zip
252.71 KB, 下载次数: 19, 下载积分: 牛币 -10
发表于 2017-6-30 22:22:36 | 显示全部楼层
什么鬼,,留名先
发表于 2017-6-30 22:33:39 | 显示全部楼层
很需要这种软件,,然而,,英文看着累。。。
发表于 2017-6-30 23:22:00 | 显示全部楼层
zxc850414 发表于 2017-6-30 22:22 搬运一个APM 日志分析软件,直观方便、感觉不错! APM,GPS,直观是啥意思,什么是直观,直观的方式 作者:湛江雷州市 7162
什么鬼,,留名先
留名中。。。
发表于 2017-7-1 01:13:48 | 显示全部楼层
软件不错。一般情况下,日志是看不懂的。有了这个软件,就会方便的多。
发表于 2017-7-1 01:43:48 | 显示全部楼层
哪位大神汉化下就66666了
发表于 2017-7-1 10:00:09 | 显示全部楼层
一直在用 不错
发表于 2017-7-1 10:09:32 | 显示全部楼层
那个日志我倒是看的懂 这个英文太多了看不懂了搬运一个APM 日志分析软件,直观方便、感觉不错! APM,GPS,直观是啥意思,什么是直观,直观的方式 作者:紫白衣 4025
发表于 2017-7-1 11:08:34 | 显示全部楼层
看不懂啊,我的apm自动返航或降落大部分几率会在降到地面时还旋转,会翻,是怎么回事,请大神帮忙
 楼主| 发表于 2017-7-1 11:19:10 | 显示全部楼层
da007 发表于 2017-7-1 11:08 搬运一个APM 日志分析软件,直观方便、感觉不错! APM,GPS,直观是啥意思,什么是直观,直观的方式 作者:new0618 2105
pid中p会不会太小?对于450机架、常见配置,其实默认参数就很稳的。另外,对于3.2.1固件,注意滤波器频率,这个默认设置不太对。
发表于 2017-7-1 13:14:27 | 显示全部楼层
表士看不懂
发表于 2017-7-1 14:20:40 | 显示全部楼层
软件不错,谢谢楼主,支持分享
发表于 2017-7-1 14:33:10 | 显示全部楼层
new0618 发表于 2017-7-1 11:19 搬运一个APM 日志分析软件,直观方便、感觉不错! APM,GPS,直观是啥意思,什么是直观,直观的方式 作者:da007 613
pid中p会不会太小?对于450机架、常见配置,其实默认参数就很稳的。另外,对于3.2.1固件,注意滤波器频率 ...
谢谢,再调一下看看
发表于 2017-7-1 14:57:54 | 显示全部楼层
顶顶顶
发表于 2017-7-1 20:46:20 | 显示全部楼层
看不懂
发表于 2017-10-4 13:52:43 | 显示全部楼层
999999999999999999999999999999搬运一个APM 日志分析软件,直观方便、感觉不错! APM,GPS,直观是啥意思,什么是直观,直观的方式 作者:ThinkFly 7561
发表于 2017-10-9 21:26:57 | 显示全部楼层
搬运一个APM 日志分析软件,直观方便、感觉不错! APM,GPS,直观是啥意思,什么是直观,直观的方式 作者:caohaizhijia 4066 搬运一个APM 日志分析软件,直观方便、感觉不错! APM,GPS,直观是啥意思,什么是直观,直观的方式 作者:caohaizhijia 8980 先来66666
发表于 2017-11-29 15:29:29 | 显示全部楼层
我要下载,牛比呢
发表于 2017-11-29 15:43:04 | 显示全部楼层
谢谢您的APM日志分析软件分享,微信5块收到了吗? 是给了网站,还是你收到了
发表于 2018-7-15 11:09:57 | 显示全部楼层
哈哈哈哈哈哈哈哈哈哈哈哈哈哈哈哈哈
