楼主: 小茑
碳纤维塑模教程干货
发表于 2016-3-24 19:17:02 | 显示全部楼层
来学习一下碳纤维塑模教程干货  作者:肃穆浩 5864
发表于 2016-3-24 23:37:43 | 显示全部楼层
                           顶
发表于 2016-3-25 06:40:40 | 显示全部楼层
我来看看学习一下
 楼主| 发表于 2016-3-29 10:01:01 | 显示全部楼层
Wet the cloth out with some epoxy resin.
用环氧树脂把编织布打湿。
碳纤维塑模教程干货  作者:小茑 3957
 楼主| 发表于 2016-3-29 15:07:14 | 显示全部楼层
When hardened, sand the edges ofthe cloth surface, to clean the Plug up and get it ready for fairing.
Coat the the Plug's glass fiber surface with a fairing compound, so you can sand the Plug smooth, ready to cast a Mold off of it.
My fairing compounds are made from epoxy resin, thickened with Q-cell for ease of sandability,
Cabosil to thicken and add thixotropic properties, and sometimes Graphite powder to add blackness,
and to aid in seeing what you're doing, or for hardness and slickness.
当变硬一些之后,把编织布的边缘给磨平,把模型清理干净备用。自制的整流罩化合物把模型玻璃纤维的表面
给罩起来,备用,一会要用来做模型。我的整流罩化合物是用环氧树脂做的,用Q-cell加厚,这样易于打磨,
胶态氧化硅要加厚,然后加上一些有触变性的东西,比如石墨粉,既可以增加硬度和光滑度,也能增加黑度
 楼主| 发表于 2016-3-29 15:11:14 | 显示全部楼层
Nice and slick: For the last stepon the plug below, I quickly mixed some 5-min epoxy gluewith graphite powder,
and rubbed it all over the plug with my finger. It's thicker viscosity makes it settle really smooth.
To bring the surface to a really good class "A" finish, wet sand with 400grit, then 800, then 1200grit.
Now time for compounds.
Use a medium cut cleaner, and rub the hell out of the surface, then buff with a clean towel.
Now do it again with 3M hand-glaze, and that sucker will really shine!
塑模最后一步:我把石墨粉和环氧树脂胶水混在一起快速搅拌(最少要5分钟)然后用手指均匀涂在模型上。
为了能让表层看起来还不错,湿砂抛光用的是400号砂纸,再来是800号,再来是1200号。接下来:用中性的清洁剂,把表层上抹出来的脏东西擦出来,再用干净的毛巾擦掉,然后再用3M皇家保养剂重复以上步骤。
最后就会很blingbling
碳纤维塑模教程干货  作者:小茑 132
