2723查看 | 11回复
Ubuntu下编译 ardupilot
发表于 2015-11-11 18:18:03 | 显示全部楼层 |阅读模式
几个月前下载 ardupolit  轻松就编译了apm2, 这次想编译 pixhawk缺遇到些问题,下面具体说说(环境pc机,ubuntu14.04):
根据官方文档 http://dev.ardupilot.com/wiki/building-the-code-onlinux/
先安装git ,  而后用 git clone下载源文件
1)下载源代码
sudo apt-get -qq -y install git
git clone https://github.com/diydrones/ardupilot.git
(如果不想clone整个库,到https://github.com/openpilot/OpenPilot下载zip文件有问题,因为编译过程中会调git命令取文件取不到,因为没有git库)
2) 而后安装toolchain (如:arduino-core,  gcc-avr avrdude avr-libc binutils-avr 等)
最简单就是运行下面脚本(提示不多,可能等很长时间)
ardupilot/Tools/scripts/install-prereqs-ubuntu.sh -y
不运行这个脚本,就要手动运行下面命令
sudo apt-get install gcc-avr avrdude avr-libc binutils-avr
sudo apt-get install python-serial python-wxgtk2.8 python-matplotlib python-opencv python-pexpect python-scipy
sudo apt-get gawk make git arduino-core g++
pixhawk 需要下载 arm toolchain
在ubuntu14.04不要用sudo apt-get install gcc-arm-none-eabi -y, 不但安装了错误的版本,而且缺少 c++ header
而应该运行 http://dev.px4.io/starting-installing-linux-boutique.html 提示的脚本(用wget 下载,再安装)
3)编译
使当前shell 环境变量生效
. ~/.profile
编译多轴
cd ardupilot/ArduCopter
make
根据提示选择target
Targets
  px4-v1 - the PX4v1 board
  px4-v2 - the Pixhawk
  pxf - the Beagle Bone Black (BBB) + PXF cape combination
  navio - the RaspberryPi + NavIO cape combination
  linux - a generic Linux build
  flymaple - the FlyMaple board
新版本的ArduCopter(3.x) 不支持缺省参数,而且取消了 apm1/apm2, 添加了树莓派的支持
比如编译 pixhawk
make px4-v2
ArduPlane  APMrover2 AntennaTracker 与此类似
最后看到下面提示,就成功编译生成文件
LINK:    /home/payne/ardupilot/ardupilot/modules/PX4Firmware/Build/px4fmu-v2_APM.build/firmware.elf
BIN:     /home/payne/ardupilot/ardupilot/modules/PX4Firmware/Build/px4fmu-v2_APM.build/firmware.bin
%% Generating /home/payne/ardupilot/ardupilot/modules/PX4Firmware/Build/px4fmu-v2_APM.build/firmware.px4
make[2]: Leaving directory `/home/payne/ardupilot/ardupilot/modules/PX4Firmware/Build/px4fmu-v2_APM.build'
%% Copying /home/payne/ardupilot/ardupilot/modules/PX4Firmware/Images/px4fmu-v2_APM.px4
make[1]: Leaving directory `/home/payne/ardupilot/ardupilot'
   text    data     bss     dec     hex filename
901640    2812   62352  966804   ec094 /home/payne/ardupilot/ardupilot/modules/PX4Firmware/Build/px4fmu-v2_APM.build/firmware.elf
PX4 ArduCopter Firmware is in ArduCopter-v2.px4
最后用 make px4-v2-upload 上传
其他问题:
我想到ArduPlane去编apm2 ( Copter取消了对apm2的支持,Plane应该没有取消吧)
但提示
ArduPlane$ make apm2
../mk/targets.mk:13: *** apm2 is deprecated on master branch; use master-AVR
那么就先运行
git checkout master-AVR
再编就可以了
make apm2
得到
%% ArduPlane.elf
Firmware is in ArduPlane.elf
%% ArduPlane.eep
%% ArduPlane.hex
发表于 2015-11-11 18:33:13 | 显示全部楼层
看不懂不知道是做什么的
发表于 2015-11-11 18:52:11 | 显示全部楼层
不懂帮顶
 楼主| 发表于 2015-11-11 20:48:01 | 显示全部楼层
无机翼的飞机8 发表于 2015-11-11 18:33
看不懂不知道是做什么的
就是生成 apm, pixhawk的固件
发表于 2015-11-11 21:21:46 | 显示全部楼层
我也不懂,以后学习
发表于 2015-11-11 23:29:07 | 显示全部楼层
Ubuntu下编译 ardupilot DIY,多轴,APM,ardupilot,ubuntu 作者:huchuang886 3413
发表于 2015-11-12 02:53:09 | 显示全部楼层
嗯。我也编译了。差不多一样的环境。
还编译了地面站APM2,我还给github项目提交过代码。未来大家的电脑/无人机里也许有运行我写的一些代码。
发表于 2015-11-12 06:30:19 | 显示全部楼层
哦就是升级成固件的
发表于 2015-11-12 07:35:29 | 显示全部楼层
这是标准的技术贴,得顶!
发表于 2015-11-12 08:33:28 | 显示全部楼层
标记下,以后可能用到到。
发表于 2015-11-12 22:46:43 | 显示全部楼层
看的一塌糊涂啊,一看就是高人,高人能不能弄个能说话的手机地面站呢,不用翻墙的。
