828查看 | 2回复
【Z-Copter 新品】FLIP32 MINI (Without Compass)飞控
发表于 2015-8-24 09:44:46 | 显示全部楼层 |阅读模式
. The smallest Flip32, runs Baseflight or Cleanflight software
. 33x16.5 mm
. 2 gram without headers
. 3-axis MEMS gyro+accelerometer (MPU6050)
. Pressure sensor (MS5611)
. STM32F103CBT6 32-bit Cortex M3 processor
. Direct conntect to Airbot 35x35 GPS /Compass
. Only supports PPM RC Input
. 6 motor outputs for multirotor mode, incl. pads for Battery voltage monitoring
. Additional UART pads for Battery and Buzzer
. Direct connection of spectrum satellite
. Onboard MicroUSB for setup and configuration
. MultiWii-based configuration software for easy setup
. NOTE: This is a PPM sum/S-bus/Spectrum satellite controller only. Make sure to add an ppm encoder if you want to use a normal pwm rx
【Z-Copter 新品】FLIP32 MINI (Without Compass)飞控 飞控,GPS,cleanflight,app 作者:xuhan3344 3976
产品零售价:10DOF / 170元      6DOF / 145元   (10DOF比6DOF多增加个气压计,根据需求选购其他功能一样)
物品淘宝链接:https://item.taobao.com/item.htm?spm=0.0.0.0.19bJP9&id=521467600819
官方直营店址:shop112716984.taobao.com
官方千人玩家群:236284685
【Z-Copter 新品】FLIP32 MINI (Without Compass)飞控 飞控,GPS,cleanflight,app 作者:xuhan3344 5066 【Z-Copter 新品】FLIP32 MINI (Without Compass)飞控 飞控,GPS,cleanflight,app 作者:xuhan3344 7964
发表于 2015-8-24 10:13:23 | 显示全部楼层
怎么这么多新奇的东西   【Z-Copter 新品】FLIP32 MINI (Without Compass)飞控 飞控,GPS,cleanflight,app 作者:突突 8204
发表于 2015-12-24 09:27:08 | 显示全部楼层
这么多新奇的东西
