先上图
[size=14.399999618530273px]首先我要在这里感谢机架的设计者 Terper 和 Dick ,正是因为你们无私的分享出了设计图纸,我才可以在这里撰写出这篇教程。你们的设计非常棒,而我则愿将这样的优秀机架毫无保留的分享给广大模友们。
First of all, I wanna say many thanks to Terper & Dick. You guys have shared your great design in full detail, I can’t finish this thread without your work. It is a fantastic wooden frame, that’s the reason I will share this to the world! [size=14.399999618530273px]【图纸】放出的是可以直接用于激光切割的AutoCAD DWG格式。(全套图纸可在本帖的结尾处进行下载)
[size=14.399999618530273px]【About the Plan】It’s abusolutely AutoCAD “DWG” file, So you can do the laser cut easily.
[size=14.399999618530273px]【文字】双语描绘“昆塔480”是怎样从一块木板变成一架飞行器的。
[size=14.399999618530273px]【About the Text】It’s fully detailed describe from 0% to 100%. In both Chinese & English.
[size=14.399999618530273px]【图片】表达的是实物制作照片与3D效果图的双视角展示。
[size=14.399999618530273px]【About the Picture】Step by step process,Demonstrated in real photo & CG Pitures.
[size=14.399999618530273px]【视频】展现的是“昆塔480”+“开源APM飞控”飞行效果。
[size=14.399999618530273px]【About the Video】Show you how KONTA 480 fly with 3DR APM Autopilot.
[size=14.399999618530273px]本帖的目的
[size=14.399999618530273px]在让大家能够参与DIY,利用手边的资源,跟着教程经济廉价打造出属于自己的木质飞行器“昆塔480”。望新手们能够通过教程感受到制作的乐趣,老鸟们也请您在过目之后给出留下更好的提议,让我们大家一同来感受木质机架的独到之处吧。需要说明的是,昆塔480是纯种的国人原创设计。所以我决定双语写作该贴,将昆塔480分享给世界。
[size=14.399999618530273px]I hope this tutorial could be clear enough to guide you build your own KONTA 480. For the beginner, I wish it could help you understand the wooden frame structure. For the veteran, please leave a constructive comment. Let’s explore the wooden frame, make it better & share to everyone!
[size=14.399999618530273px]特别说明:机架设计图纸与帖子图片文字都是无偿分享给模友们,请勿将本帖的图纸、图片、文字或者相关附件下载之后进行销售或其他方式用于商业活动,请尊重知识产权,建立良好的讨论气氛,让乐于分享的精神传承下去。
[size=14.399999618530273px]Important Notice: All the Plan/Text/Picture/Video are freely download. Please don’t use them for commercial activities. Please respect the Author’spurpose, Let’s do the share. Make it better!
[size=14.399999618530273px]机架规格(FrameSpecifications)
[size=14.399999618530273px](这里列出来的为视频中所使用的设备,供大伙参考用,大家完全可以根据自己的实际情况进行更灵活搭配,不必局限)
[size=14.399999618530273px]材质:椴木层板3.2mm + 椴木层板2mm
[size=14.399999618530273px](Material: Basswood Plywood 3.2mm+2mm)
[size=14.399999618530273px]轴距:480mm
[size=14.399999618530273px](Axle Base:480mm)
[size=14.399999618530273px]电机:银燕MT3506 盘式电机
[size=14.399999618530273px](Motor: Yinyan MT3506)
[size=14.399999618530273px]螺旋桨:银燕碳纤桨1147
[size=14.399999618530273px](Propeller: Yinyan Carbon Fiber 1147)
[size=14.399999618530273px]电调:银燕Simon 30A
[size=14.399999618530273px](ESC:Yinyan Simon30A)
[size=14.399999618530273px]电池:3S 5000mAh
[size=14.399999618530273px](Battery:3S 5000mAh)
[size=14.399999618530273px]飞控(Autopilot System):开源APM飞控
[size=14.399999618530273px](Autopilot System:APM)
[size=14.399999618530273px]空机架重量:210g(±10)
[size=14.399999618530273px]Frame Net Weight:210g(±10)
[size=14.399999618530273px]机架特色(Features)
[size=14.399999618530273px]经济DIY木质异型机架,可以根据自己的需要切割出额外的机臂与脚架等易损件,摔哪儿换哪儿。
[size=14.399999618530273px]Super low cost, you can laser cut extra sets of ARM & LEG, where there is a broken, there is a replacement.
[size=14.399999618530273px]无需任何螺丝,全卯榫结构,仅需一瓶502胶水即可完成机架组装。
[size=14.399999618530273px]Very easy to assembly with mortise structure, the only thing you need is a bottle of CA Glue.
[size=14.399999618530273px]异型蝗虫机架设计,造型独特的同时也保证了飞行的稳定性。
[size=14.399999618530273px]Unique motor arm design, also with nice stability.
[size=14.399999618530273px]使用502解胶剂即可将炸坏的机臂、脚架进行迅速更换。
[size=14.399999618530273px]Easy to replace the broken ARM/LEG if use the CA Glue Debonder.
[size=14.399999618530273px]机架预留有图传、数传、OSD、云台的安装孔。
[size=14.399999618530273px]Compatible with the VideoTX/Telemetry Radios/OSD/Camera Gimbal.
[size=14.399999618530273px]电调、舵机、飞控线缆采用内部走线,美观实用。
[size=14.399999618530273px]All wires have organized inside the frame for better appearance.
[size=14.399999618530273px]接下来将正式开始我们的教程,请您跟着我一步一步的来制作“昆塔480"吧!
[size=14.399999618530273px]”Okay……Time for the show! Konta 480 Action!
