6055查看 | 10回复
Rover Setup for APM autopilot
发表于 2014-12-30 12:41:27 | 显示全部楼层 |阅读模式
The process of converting an RC car to a APM:Rover consists of adding the APM autopilot in between the RC receiver and the car’s motor and steering servo. We recommend that the APM be powered by the included Power Module.
(Note: this tutorial assumes you’re using a Mode 2 radio setup. If you’re using Mode 1, the throttle will move to the other stick)
APM:Rover is designed to use regular RC transmitters (not specialized RC car transmitters) with both throttle and steering on the right stick. This is because RC cars can typically go both forwards and backwards and so the throttle should be spring-loaded to return to the mid-point, which is the case for the right up/down stick (typically the elevator stick) on regular RC transmitters. If, however, you are not using a RC car motor controller but rather a regular aircraft motor controller, which typically does not have a reverse function, you can put the throttle on the left stick as would normally be the case for an aircraft. Rover Setup for APM autopilot APM,GPS,autopilot 作者:建凯 8543
RC Setup
Connect your RC system to APM as shown below:
Input Channels:
RC RxAPM InputFunction
11Steering
23Throttle
58Mode
67Record waypoint
Output Channels:
(For standard RC cars that use a servo to steer, use the Car settings. If, however, you have a treaded tank or some other vehicle that uses different speed motors on each side to steer, use the Skid Steer settings)
APM OutputCarSkid Steer
1ServoLeft Motor
3Motor/ESCRight Motor
Reassigning your RC transmitter stick channels:
  • Although the default normal transmitter stick configuration is generally the best, APM:Rover does allow you to reconfigure them.
  • To reassign the RC transmitter sticks to other than the default channels:
    • Connect your APM’s USB port to your computer and start Mission Planner (ensure that Advanced View is turned on in the Config page to see all menu options) and Select the “Connect” button on the upper right..
    • Select the “Configuration” tab then select “Advanced Params” and the Adv Parameter List”.
    • Scroll down to the “RCMAP_ROLL, RCMAP_PITCH, RCMAP_THROTTLE and RCMAP_YAW” parameters.
    • These allow you to directly assign which radio channel (1-8) is assigned to each of the major functions.
  • This is useful when you have a flight transmitter with unusual channel assignments.
    • Or which does not allow easy channel reassignment at the transmitter
  • Additional information on these parameters may be found here.
Installing it in your car
The below shows a typical setup in a small rover, using APM, 3DR radio telemetry and both sonar and IR sensors (instructions on setting them up are here. Note a few elements:
  • The RC car’s plastic body shell has been removed and a plywood sheet cut and drilled to fit on the mounting posts.
  • APM has been raised up on a platform made of four 30mm nylon spacers, four 5mm nylon screws,  and an ArduCopter stack-up plate. This is to ensure that the sensitive compass sensor on APM is as far as possible from the magnetic noise/interference of the car’s electric motor.
  • APM, the GPS, 3DR radio and RC receiver are all powered by the APM Power Module (included with the APM set). The car’s steering servo is powered by the car’s speed controller. This is the standard setup and doesn’t require any special settings or configuration, but for those wondering about power, that’s the answer. Among other advantages, the use of the APM Power Module means that APM can do voltage and current sensing and report battery status to the Ground Station during the run, as well as datalog it for after-run analysis.
  • A larger battery than the car was originally designed for is being used (because the rover is designed to travel long distances off-road), and it is mounted on velcro under the APM platform so it doesn’t shift.
Rover Setup for APM autopilot APM,GPS,autopilot 作者:建凯 2220
Depending on the car frame you’re using, you may wish to set up your gear differently. Almost any configuration can work, but just remember to keep APMas far from sources of magnetic interference as possible! The image below shows a top view of Tom Coyle’s Slash Rover (winner of the Peloton Class at AVC 2013) with a Spektrum receiver, GPS, and external compass. Rover Setup for APM autopilot APM,GPS,autopilot 作者:建凯 4862
Connecting GPS Module
A GPS module provides enhanced positioning for autonomous flight. Connecting your GPS to your autopilot by following these steps.
3DR GPS uBlox with Onboard Compass Rover Setup for APM autopilot APM,GPS,autopilot 作者:建凯 6451 3DR GPS uBlox with Onboard Compass is intended for use with APM  (for external compass). It provides enhanced compass performance because of the freedom to situate the GPS unit in an optimal position independent of the location of the APM.
Place your GPS in an elevated position on your rover with the arrow facing forward (toward the front facing direction of your rover). Connect the GPS module to the APM using the two cables included with the GPS as shown below.
3DR GPS uBlox with Onboard Compass includes two connector cables: one 4-position cable and one 5-position-to-6-position cable. To connect the GPS module to APM, connect the GPS to the APM GPS port using the 5-position-to-6-position cable; connect the GPS to the APM I2C port using the 4-position cable.
Rover Setup for APM autopilot APM,GPS,autopilot 作者:建凯 3615
Slash Rover’s GPS with external compass mount: Rover Setup for APM autopilot APM,GPS,autopilot 作者:建凯 5697
leo2014 该用户已被删除
发表于 2014-12-30 12:46:52 | 显示全部楼层
发表于 2014-12-30 12:54:24 | 显示全部楼层
强烈要求翻译过来哦
long13198 该用户已被删除
发表于 2015-1-3 07:56:59 | 显示全部楼层
zhangbest9 该用户已被删除
发表于 2015-1-6 01:53:49 来自手机 | 显示全部楼层
fly768 该用户已被删除
发表于 2015-1-6 12:32:57 | 显示全部楼层
司马英 该用户已被删除
发表于 2015-1-6 12:39:29 | 显示全部楼层
 楼主| 发表于 2015-1-6 19:38:18 | 显示全部楼层
不懂得可以问也可以用百度翻译
发表于 2015-4-28 14:47:27 | 显示全部楼层
admin 发表于 2014-12-30 12:54
强烈要求翻译过来哦
您好,请问您是玩小车的吗?能交流些经验吗?玩小车的人太少了。
十分感激!
发表于 2015-9-23 21:23:16 | 显示全部楼层
这个原文是哪里?学习学习
发表于 2015-10-18 17:39:49 | 显示全部楼层
看见英文头大
