楼主: 泡泡
[泡泡老师教程] 新手课堂,APM MiniOSD使用第3课,关于OSD的供电问题
发表于 2015-8-11 11:33:13 | 显示全部楼层
ZWDXBB 发表于 2015-8-11 11:00
不按摄象头,不接RX TX到APM,应该能看到版本号,看不到OSD坏了
没接 RX,TX,没有版本号。
有图像,能刷固件,能上传字体。是7456坏了吗?
发表于 2015-8-11 12:23:21 | 显示全部楼层
按照您的说法,不装摄像头,能看到版本信息。
插上摄像头,就只有图像,其他都没了
发表于 2015-8-11 13:03:31 | 显示全部楼层
I installed a MinimOSD (with rush-osd-development MWii OSD firmware) on a Quadcopter with a Baseflight (Naze32 compatible) Flight Controller. The build is summarized here: http://www.rc-cam.co...acer-build-log/. I discovered that the MinimOSD would not work with several of the FPV cameras I tried. The OSD would work fine without the camera (realtime OSD data was correctly presented on black background). But when it was connected to the camera the OSD data would not appear (or would appear but not update reliably). That is to say, the video camera's image was fine, but the OSD was non-functional.
After some research it became clear that this is a popular complaint among minimOSD users. The most common theory is that high resolution cameras are to blame and that using a lower resolution camera solves it. Although this advice seems to cure the problem in a lot of installations, the reasoning is incorrect. The actual problem is that some Chinese made cameras have incorrect video sync levels. I found that the sync amplitude on affected cameras was marginal and the OSD chip could not detect the presence of vertical sync (but fortunately it could still detect horizontal sync).
难道是这问题?
 楼主| 发表于 2015-8-11 16:41:48 | 显示全部楼层
stonelee 发表于 2015-8-11 11:33
没接 RX,TX,没有版本号。
7456坏的话,你就看不到图象了。
应该是你的PCB出问题了,返修
发表于 2015-8-12 13:09:11 | 显示全部楼层
ZWDXBB 发表于 2015-8-11 16:41
7456坏的话,你就看不到图象了。
应该是你的PCB出问题了,返修
泡泡老师,现在换了个摄像头,能够看到图像,包括OSD信息的叠加也正常了。
但是现在没有数据,各种接线方法都试过了。
不知道啥原因,APM我用的是2.6,解锁,飞行都正常,连接电脑也没问题。
请问会不会是Telem端口有问题。还是波特率设置的问题?
请老师帮忙分析一下
发表于 2015-8-19 00:32:13 | 显示全部楼层
泡泡老师,我的OSD是刚买来的,还没配置,直接按照说明接上去,只显示版本号,然后就不动了。请问是什么情况?
是需要拿FTDI连上去配置下的意思?还是有故障?
屏幕上就只显示minim osd extra 2.2 copter
然后还有个连线的符号
没有收到主控的信号,检查线路是否连接错了,RX TX要交叉连接。  详情 回复 发表于 2015-8-19 15:14
 楼主| 发表于 2015-8-19 15:14:41 | 显示全部楼层
s.d.p 发表于 2015-8-19 00:32
泡泡老师,我的OSD是刚买来的,还没配置,直接按照说明接上去,只显示版本号,然后就不动了。请问是什么情 ...
发表于 2015-8-19 18:22:56 | 显示全部楼层
检查多次确定连接没问题,可是故障依旧.请问是否有可能OSD哪个部分挂了
发表于 2015-8-19 22:24:26 | 显示全部楼层
刚才检查APM版,发现后面的跳线焊盘没焊,于是焊上。接下来就发生了一起惨绝人寰的悲剧。
上电,OSD直接冒烟,APM也一并烧坏。。。。
原因未知,请泡泡老师分析。OSD的5V触点处于焊上的状态,但是左边的5V也接了,是因为这个么?
不是教过你们,如果OSD上的JP短接的话,左侧不要接APM 5V上去吗? 你电调供电,经二级管和保险电阻降压到APM上的电压只有4.6V左右,而OSD上的JP短接后,左侧5V针脚是有电压输出的,应该大于4.6V, 这么一来,等于是O  详情 回复 发表于 2015-8-20 14:54
我少说一件事,用的是什么给APM供电的,是电调?还是外接BEC,还是电压电流传感器?  详情 回复 发表于 2015-8-20 09:34
 楼主| 发表于 2015-8-20 09:34:50 | 显示全部楼层
上电,OSD直接冒 ...
你少说一件事,用的是什么给APM供电的,是电调?还是外接BEC,还是电压电流传感器?
发表于 2015-8-20 13:58:17 | 显示全部楼层
用的是电调,好盈天行者30A的电调给APM供电
 楼主| 发表于 2015-8-20 14:54:23 | 显示全部楼层
上电,OSD直接冒 ...
这么一来,等于是OSD给APM在供电,由于OSD上的降压模块供电电流不够,直接烧了,高电压进入APM,连带APM一起烧坏。
自己不好好上课,怪不的别人。
新手课堂,APM MiniOSD使用第3课,关于OSD的供电问题  作者:泡泡 245
发表于 2015-8-20 23:03:27 | 显示全部楼层
你电调供电,经二级管和保险电阻降压到A ...
深切反省,看帖不认真。。。。。。。唉
发表于 2015-8-21 15:10:24 | 显示全部楼层
按照泡泡老师的办法,已经在新的OSD上实验成功了,但是我想用山狗做图传摄像头,请教如何不用12V又能有图像?
不想接12V到OSD的话,左侧接5V BEC,右侧不接12V进去就行了。  详情 回复 发表于 2015-8-21 16:36
 楼主| 发表于 2015-8-21 16:36:15 | 显示全部楼层
s.d.p 发表于 2015-8-21 15:10
按照泡泡老师的办法,已经在新的OSD上实验成功了,但是我想用山狗做图传摄像头,请教如何不用12V又能有图 ...
发表于 2015-8-29 15:48:07 | 显示全部楼层
好教程不错
发表于 2015-10-20 20:02:16 | 显示全部楼层
兄弟 问问你 ,怎么用电调或者BEC 给 OSD 供电呢 线是哪里出来的哦
发表于 2015-10-20 20:02:19 | 显示全部楼层
发表于 2015-10-20 20:02:23 | 显示全部楼层
发表于 2015-10-20 20:02:32 | 显示全部楼层
