813查看 | 4回复
First Time FPV Tips 第一飞行技术 转老外
发表于 2014-10-1 22:29:48 | 显示全部楼层 |阅读模式
First Time FPV Tips (from a noob)
So you've got your FPV gear but feel like a bit of a noob? A bit nervous of the first time pulling on the goggles? Here are a few practical tips about learning to fly basic FPV.
Recently I was, like many people, nervous and hoping I wasnt going to write off all my new FPV stuff. After analysing my video footage from the first flight, I have compiled a few tips and tricks for my next flight I thought I would share for anyone out there in a similar position as me.
By the way, these are just my personal tips, if you're an experienced pilot, you may find these are not all nessisarily tips you would have given, but I find they helped me out and may help someone else out too.
第一次废票提示(从新手)
  所以你有你的废票齿轮但感觉有点新手吗?有点紧张,第一次把护目镜?下面是一些实用的小贴士学习飞行基本废票。
  最近,我和许多人一样,紧张,希望我没有去注销我的所有新的废票的东西。从第一次飞行分析我的视频后,我收集了一些提示和技巧为我的下一个航班,我想我还是分享任何和我在一个类似的职位。
First Time FPV Tips   第一飞行技术 转老外 电池,gopro,app 作者:24k纯帅 2946
Top Tip 1 - Get your goggles comfortable
This is pretty important for a good experience. If you're using goggles as I do, make sure the eye cups fit nicely over your eyes and your strap is tight to stop the whole lot slipping down your face. I had my goggles decide to slip very slightly so the image went blurry several times during my flight. Make sure its really secure arround your head before flying. Also make sure the battery isnt going to dislodge. This happened to me too. It was rather irritating and I had to take my hands off the controlls several times to be able to see properly. Thankfully my good friend acting as copilot and spotter was able to help me out with these goggle issues, but you really want to be concentrating on flying all the same。
提示1 -让你的眼镜舒适
  这是非常重要的一次很好的经历。如果你使用护目镜和我一样,确保眼杯非常适合你的眼睛和你的皮带紧停止下滑你的脸。我眼镜决定滑略微那么多次图像去模糊在我的航班。确保其真正飞行前头部周围的安全。还要确保电池不是要驱逐。这发生在我身上。它很刺激
First Time FPV Tips   第一飞行技术 转老外 电池,gopro,app 作者:24k纯帅 4139
Top Tip 2 - Make sure your FPV aircraft is really well trimmed
Before you go all FPV mode, set up the plane so it handles really well. It may be kind of obvious, but really its very important. The weather can also play an important part in the behavior of a plane, which is what I'm coming up to next.
技巧2 -确保你的废票飞机是修剪得很好
  在你走之前所有废票模式,建立飞机所以它处理得很好。可能是显而易见的,但真的很重要。天气也可以发挥重要作用的行为一架飞机,这是我来了下一个。
First Time FPV Tips   第一飞行技术 转老外 电池,gopro,app 作者:24k纯帅 3845
Top Tip 3 - Make sure you know what the weather is doing
It may look calm, but the weather may be pretty different at various altitudes. I learned this the hard way as I failed to launch successfully several times, nosediving painfully into the ground and not knowing why. Turned out there was a low pressure area in the field I was in because of the wind going over the top of the hill and missing this area. This made it hard to get any lift low dow and it was turbulent higher up . It can be very frustrating if you don't know why your plane isn't flying very well when it was doing perfectly in the same location a day before and everything looks calm. If it is windy in one area near you but calm where you are, be suspicious! Try and pick a sunny bright day too. It's easier to see things when everything isn't just grey and misserable.
前提示3 -确保你知道天气做什么
  它可能看起来平静,但天气可能是非常不同的在不同的海拔。我知道其中的艰辛,因为我没能成功发射几次,锐减痛苦地在地上,不知道为什么。原来有一个低压区在这一领域我是在因为风的山顶和失踪。这使得很难阿凡提低道和动荡的更高。它可以非常frustra
First Time FPV Tips   第一飞行技术 转老外 电池,gopro,app 作者:24k纯帅 331
My first FPV flight (above) was on a slightly overcast evening. Light levels were low which wasn't ideal as the ground was pretty dark and undetailed through the FPV cam.
Top Tip 4 - Carry some speed to avoid stalling
Looking back at my footage, I noticed I was on the verge of stalling several times through taking it too slow. This was especially concernful as I was flying close to some trees at the time. I had been told to fly low too, so I can recognise landmarks easily, however this combined with painfully slow speeds looked, in hindsight, worryingly like they would end in a crash. Keep the throttle up and only fly arround half the battery to make sure you don't run out of juice. It may be difficult to judge your speed when flying in first person for the first time, but be aware of where the stick is.
 我第一次废票飞行(上图)是在一个稍微阴暗的夜晚。光水平较低,并不理想,因为地上很黑暗和undetailed废票凸轮。
  高级技巧4——携带一些速度,避免拖延
  回顾我的镜头,我注意到我几次被停滞的边缘通过太慢。这是特别重要的,因为我当时飞行接近一些树。我被告知飞低了,所以我可以轻松地识别地标,然而这种结合
First Time FPV Tips   第一飞行技术 转老外 电池,gopro,app 作者:24k纯帅 607
Here I was flying slowly up a hill that had low air pressure. A bit silly in hindsight seeing as though this was my first fpv experience. Keep it higher and faster to avoid a catastrophe.
Top Tip 5 - Know your playground
If you listen to the FT podcast a lot like I do, you've probably heard Bixler say this a few times; "Know your playground and fly a pattern". It really helps if you pick out landmarks, be it a house you're near, trees etc, or far off places like a town in the distance. Try flying from one to the other, turning when you get there and flying to another landmark. Do this at a fairly high up altitude and make sure you keep asking your spotter where you are in relation to your body on the ground and where you're heading, even if you think you know. However, you should be able to know roughly where you are in the sky by the sound of the motor onboard the aircraft. Life is good.
在这里,我是慢慢飞上山气压低。有点愚蠢事后看到,好像这是我第一次废票的经验。更高,更快,从而避免灾难的发生。
  提示5 -知道你的游乐场
  英国《金融时报》如果你听播客很多像我一样,你可能已经听到Bixler说这几次,“知道你的操场和驾驶模式”。它真的帮助如果你挑选地标,附近的一个房子你、树木等,或远离这样的地方在远处的一个小镇。试着飞f
First Time FPV Tips   第一飞行技术 转老外 电池,gopro,app 作者:24k纯帅 1893
You don't have to actually draw a map obviously, but it does help to have a rough idea in your head about where you're going to go and where you're not. Stick to the plan too.
Top Tip 6 - Plan what you're going to do really thoroughly!
Go over in your head what your plan of action will be. What pattern are you going to fly? How long are you going to go FPV for? How long will you fly before pulling on the goggles? Going over and over everything in detail will make sure you don't do anything wrong. Maybe have a mental checklist.
Make sure you don't forget to check all of your systems, not just the FPV video system. Be sure that they are all working as expected before launch. Take your time. Keep calm. Forgetting to do this is quite silly really isn't it, and it's just as important as having your video link solid.
Hopefully you will have found some of this advise helpful. I know it's the sort of thing I needed before I flew FPV for the first time. Apart from all this, good luck, and have a good flight! Relax and enjoy the experience you've been waiting for.
Here is my flight video (before I flew FPV for the first time) from the night I was testing the GoPro; It has more visually apealing footage than my FPV flight so I thought I would share this instead.
- See more at: http://flitetest.com/articles/fi ... thash.gOUWS2Pg.dpuf
实际上你不需要画一个地图很明显,但它确实帮助有一个粗略的想法在你的脑海中对你要去的地方,你不是。坚持这个计划。
  前提示6 -计划你要做什么真的彻底!
  走在你的头你的行动计划。你要飞是什么模式?你打算去废票多长时间?你多长时间拉在镜前飞吗?会一遍又一遍的一切细节将会确保你不会做错什么事。
First Time FPV Tips   第一飞行技术 转老外 电池,gopro,app 作者:24k纯帅 2328
发表于 2014-10-1 22:54:09 | 显示全部楼层
图片我已经给从新上传到论坛了,以后发帖不要光复制粘贴,图片要发到我们论坛服务器上来,外来的图片链接不可靠!
重新截图上传 哦哦 知道啦  详情 回复 发表于 2014-10-1 23:04
 楼主| 发表于 2014-10-1 23:04:47 | 显示全部楼层
admin 发表于 2014-10-1 22:54 First Time FPV Tips   第一飞行技术 转老外 电池,gopro,app 作者:24k纯帅 2002
图片我已经给从新上传到论坛了,以后发帖不要光复制粘贴,图片要发到我们论坛服务器上来,外来的图片链接不 ...
重新截图上传  哦哦 知道啦
发表于 2014-10-2 13:38:41 | 显示全部楼层
什么破翻译,整个不知道在说什么
。。。  详情 回复 发表于 2014-10-2 14:25
 楼主| 发表于 2014-10-2 14:25:22 | 显示全部楼层
沈淼章 发表于 2014-10-2 13:38 First Time FPV Tips   第一飞行技术 转老外 电池,gopro,app 作者:24k纯帅 5647
什么破翻译,整个不知道在说什么
