因准备玩APM飞固定翼,先行学习了部分WIKI内容,也就跟着做了个手册,同各位魔鬼共享下,不到的地方大家共同研究有错及时指出。学习的内容网址是:http://code.google.com/p/ardupilot-mega/wiki/home?wl=zh-Hans
APM固定翼设置简要手册_方少版(741.30K)
APM固定翼设置完整手册(方少版)(1.37M)
关于原文中说的气压计中的问题,原文是这样的,水平有限,请大家翻译。
Or NotIf you aren’t using the enclosure, make sure to cover the barometric sensor with some open cell foam, cotton padding or tissue to protect it from prop wash, wind and turbulence. Also, the barometric sensor is sensitive to light and readings can change by several meters from direct sunlight to shade. Some type of light shield (on top of the foam) will minimize the effects of light changes.
