1059查看 | 5回复
【大力电子】T8FG/T12FG 工程模式SD卡自动创建程序
发表于 2014-5-1 22:21:36 | 显示全部楼层 |阅读模式
Tools to create futaba T8FG service activator SD card.
1. Make sure the SD card was proper formatted by T8FG trasmitter.
(No matter there is model data in it)
2. Insert card to SD card reader and run T8FGService.exe
3. Select the correct drive where your SD card is in.
4. Click ok and wait the procedure complete.
5. Eject the card and insert into T8FG
6. Powre on T8FG and the service menu appears automaticly.
7. When your want reuse the SD card in T8FG to store model data. Just delete TINYFS.IMG in card root directory or format the card in OS.
** WARRING: OWN YOUR RISK TO MODIFY SERVICE MENU SETTINGS **
Futaba T8FG 工程模式激活工具
1. 把SD卡放入控中格式化 (无需空卡)
2. 把SD卡放入读卡器,并启动 T8FGService.exe 程序
3. 选择SD卡对应的驱动器符
4. 点击“OK”等操作完成
5. 弹出SD卡,插入T8FG中
6. 打开T8FG电源,工程菜单会自动显示
7. 如果还需要使用这张卡存放模型数据,删除TINYFS.IMG文件或在操作系统中格式化。
** 警告:小心使用工程菜单,自担风险 **
modify KEY.dat file to do other function. (Any string else to disable service function)
'T8FG  TEST(NORESET)' - Shows all service menus and allows making all the changes.
'T8FG  TEST(LIMIT  )' - Shows only a sub-set of service menus, with limited editing possibilities. E.g. Cannot change the product id, band, area...
'T8FG  TEST(RST SS )' - Don't Known SS stands for
'FX-20 TEST(RST SS )' - Do service FX-20, Don't know SS.
'T8FG  TEST(RST PCM)' - Don't Known detail, maybe reset PCM module locate
'FX-20 TEST(RST PCM)' - Do service FX-20, Reset PCM Module.
'T8FG  TEST(NOEDIT )' - Shows all service menues, but prevents any changes. Includes an RF test screen.
'T8FG  TEST(TELEC  )'  - Don't known what's purpose
'T8FG SCREEN SHOT   ' - A screen shot of TX can be made with SW-H. Screen shots are stored on SD card and can be extracted with ffs.exe tool.
'T8FG  TEST SHOT    '  - maybe simular to screen shot
This program can be used for T12FG too. Just use following code in KEY.dat instead.
'T12FG TEST(NORESET)' - Shows all service menus and allows making all the changes.
'T12FG TEST(LIMIT  )' - Shows only a sub-set of service menus, with limited editing possibilities. E.g. Cannot change the product id, band, area...
'T12FG TEST(RESET  )' - Hard reset of the TX. All memory is cleared, total power on time is reset, product id is cleared, stick calibration is reset...
'FX-30 TEST(RESET  )' - I don't have FX-30, so I never tried it. Don't know what it does.
'T12FG TEST(NOEDIT )' - Shows all service menues, but prevents any changes. Includes an RF test screen.
'T12FG SCREEN SHOT  ' - A screen shot of TX can be made with SW-H. Screen shots are stored on SD card and can be extracted with ffs.exe tool.
下 载地址:
http://starmoon.org.cn/share/software/RC/T8FGService.rar
发表于 2014-5-1 23:05:09 | 显示全部楼层
发表于 2014-5-1 23:06:05 | 显示全部楼层
前排支持下
发表于 2014-5-4 14:41:33 | 显示全部楼层
:o
发表于 2014-5-4 14:42:19 | 显示全部楼层
站位支持
发表于 2014-5-5 12:05:40 | 显示全部楼层
前排顶,很好!
