667查看 | 6回复
【大力电子】最新遥控延时速度比较表
发表于 2014-4-30 15:23:44 | 显示全部楼层 |阅读模式
DSM, DSM2, FASST, XPS in eCCPM mode
Transmitter    |Receiver|MLF|MLL|MaxLF|MaxLL|Avg
ATX RD8000     |92824   |14 | 19| 34.3| 39.3| 26.8
ATX SD-10G     |92104   | 4 | 10| 10.3| 16.3| 10.3
ATX SD-10G     |92104   | 4 |  4| 16.3| 16.3| 10.3 (10)
Futaba 8FG     |R6008HS |11 | 11| 17.7| 17.7| 14.1  (9)
Futaba 8FG     |R6008HS |11 | 11| 24.8| 24.8| 17.6
Futaba 10C/TM10|R6008HS | 8 |  9| 15.2| 15.2| 11.7  (9)
Futaba 10C/TM10|R6014FS | 7 |  7| 28  | 28  | 18
Futaba 12Z/TM14|R6014FS |19 | 19| 57.8| 57.8| 38.4
Futaba 14MZ/DM8|AR9000  |20 | 23| 74  | 76  | 47    (4)
Futaba T6EX    |R606FS  | 8 | 15| 54  | 60  | 34.25 (5)
Futaba T7C 2.4 |R617FS  |11 | 13| 39  | 41  | 26yue4ri
Hitec Aurora 9 |Optima 7|41 | 46| 62.6| 72.6| 55   (11)
Hitec Aurora 9 |Optima 7|41 | 43| 62.6| 66.6| 53.5 (12)
JR 12X         |R1221   |20 | 21| 43.5| 45.5| 32.5
JR 9303/Spektru|AR9000  |40 | 45| 63.8| 68.3| 54.4
JR 9303/XPS Tol|XPS 8-ch|34 | 52| 74  | 81  | 60    (7)
JR 9303/XPS Now|XPS 8-ch|33 | 33| 61.7| 61.7| 46.9  (8)
JR X9303       |AR7000  |24 | 26| 45.5| 49.5| 36.2
JR X9303       |R921    |24 | 26| 45.5| 49.5| 36.7
Spektrum DX6   |AR6000  |59 | 63| 80.6| 88.6| 72.8
Spektrum DX6i  |AR7000  |23 | 25| 47.6| 49.6| 35.74
Spektrum DX7   |AR7000  |14 | 16| 36  | 40  | 27.5
Spektrum DX7   |AR6100  |14 | 16| 36  | 40  | 27.5
Spektrum DX7   |AR6000  |31 | 35| 53  | 61  | 45
Spektrum DX7SE |        |12 | 13| 20  | 22  | 17
PCM in eCCPM Mode
ATX Stylus     |92186Z  |13 | 16| 27  | 30  | 21.5
Futaba 10C     |R319DPS |13 |   |     | 43  | 28
Futaba 12Z     |R5014DPS|14 | 14| 31.5| 31.5| 22.75 (1)
Futaba 12Z Md A|R5114DPS|11 | 11| 29.5| 29.5| 20.3  (1)
Futaba 12Z Md B|R5114DPS|15 | 15| 37.6| 37.6| 26.1  (1)
Futaba 14MZ    |R5014DPS|14 | 14| 31.5| 31.5| 22.75 (1)
Futaba 14MZ    |R5014DPS|14 | 24| 31.5| 41.5| 27.75 (2)
Futaba 14MZ    |PCM1024 |29 | 93| 42  |106  | 67.5  (3)
Futaba 9C      |R149DP  |44 |110| 57  |123  | 83.5
Futaba 9ZWC2   |R149DP  |29 | 93| 41.9|105.9| 67.5
Hitec Eclipse7 |QPCM    |41 | 43| 62  | 64  | 52.5
JR 8103        |649S    |27 | 59| 47  | 59  | 48
JR 9303        |649S    |15 | 47| 36  | 47  | 36.3
JR 9303        |770S    |15 | 47| 36  | 47  | 36.3
JR 10X         |649S    |34 | 66| 54  | 66  | 55
PPM and eCCPM
ATX Stylus    |FM      |13  | 17| 37  | 45  | 28
Futaba 10C    |FM      | 2.5|   |     | 24.9| 13.9
Futaba 14MZ   |PPM8    | 4  |  6| 39  | 41  | 22.5 (1)
Futaba 9C     |FM      |50  | 55| 72.3| 82.3| 64.9
Hitec Eclipse7|FM      |22  | 28| 42.6| 50.5| 35.8
JR 8103       |FM      |10  | 14| 32  | 40  | 24
JR 9303       |FM      |10  | 14| 32  | 40  | 24
JR 10X        |FM      |10  | 14| 32  | 40  | 24
Multiplex Evo9|FM      |10  | 14| 32  | 40  | 24 (6)
PCM, DSM2, and FASST in Normal mode (Channel 6)
ATX Stylus    |92186Z  |13 | 13| 27  | 27  | 20
Futaba T6EX   |R606FS  |17 | 17| 61  | 61  | 39
JR 8103       |649S    |38 | 38| 58  | 58  | 53
JR 10X        |649S    |35 | 35| 55  | 55  | 50
JR X9303      |R921    |25 | 25| 47  | 47  | 36
PPM and Normal (Channel 6)
Futaba 9C     |PPM     |32 | 32| 59.3| 59.3| 45.65
Futaba 14MZ   |PPM8    | 3 |  3| 40  | 40  | 21.3
JR 8103       |PPM     |16 | 16| 38  | 38  | 27
JR 10X        |PPM     | 8 |  8| 30  | 30  | 19
All times are in milliseconds.
MLF - Minimum latency to first change at receivers output
MLL - Minimum latency to last change at receivers output
MaxLF - Maximum latency to first change at receivers output
MaxLL - Maximum latency to last change at receivers output
Avg - Average of MLF, MLL, MaxLF, and MaxLL
(1) Using channels 4, 5, and 6
(2) Using channels 1, 2, and 6
(3) Deduced numbers from observed behavior
(4) Channels 4, 5, and 6 on 14MZ and channels 2, 5, and 6 on AR9000
(5) Subject to collective input slew rate limiting
(6) In PPM 8, JR channel assignments, HELIccpm model and NOT an IPD receiver
(7) Units sold in Toledo
(8) Current tx module firmware v2.3 and rx firmware v2.4
(9) High speed mode
(10) Using channels 1, 4, and 7
(11) Using channels 1, 2, and 6
(12) Using channels 1, 2, and 3
发表于 2014-4-30 17:28:22 | 显示全部楼层
沙发???
发表于 2014-4-30 17:30:19 | 显示全部楼层
沈淼章希望我们成为朋友
发表于 2014-5-2 08:40:21 | 显示全部楼层
呵呵
发表于 2014-5-2 08:40:46 | 显示全部楼层
前排,哇咔咔
发表于 2014-5-5 00:48:38 | 显示全部楼层
LZ敢整点更有创意的不?兄弟们等着围观捏~
发表于 2014-5-5 00:48:41 | 显示全部楼层
山人顶你到天亮
