日本双叶电子(Futaba)公司的4PKS遥控器有新版本上市,新版本4PKS将附带R614FS四通道接收机。R614FS内置双天线和Pre-Vision监测机能,确保传输信号安全清晰。4PKS遥控器支持40组模型参数记忆、内置攀爬遥控车调整特性,2.4GHz FASST传输技术。4PK系列遥控自上市以来受到广大遥控车玩家欢迎,新版本4PKS出现,延续了系列产品的生命,同时丰富了产品的功能,尤其是攀爬遥控车和仿真类型遥控车玩家终于可以使用双叶(Futaba)原厂的四通道接收机。
- LCD offers adjustable contrast, “Display” setting to allow setup without transmitting and
- the chance to view up to 36 functions at once.
- The multi-functional jog button with red LED makes navigating the menus easy
- Grip features a built-in vibrator that can be used as a lap timer, up timer , navigation aid or as a low-voltage alert
- A drop-down adapter is included for repositioning wheel height and angle for maximum comfort
- Extra protection features include high-voltage and low-battery alarms and auto shutdown after ten minutes of inactivity
The R614FS 2.4GHz FASST 4-Channel Receiver - Easy Link for establishing an instant, unbreakable transmitter-receiver link
- Dual Antenna Diversity monitors two antennas, and selects the strongest to ensure the best reception
- Normal/High Speed mode auto detection
- Pre-Vision detects and corrects errors in incoming data for an even clearer signal
- Lightweight (0.28 oz./7.8 g) and ultra-compact size: 35 x 23 x 8.5 mm/1.38x.91x.33”
- High-voltage design (3.7V – 7.4V) for use with a wide range of NiCd, NiMH or LiPo packs
