673查看 | 4回复
【大力电子】Futaba T3PM 攀爬车遥控器
发表于 2014-4-12 09:59:03 | 显示全部楼层 |阅读模式
Futaba 的T3PM推出专为攀爬遥控车使用的款式!具备四轮转向操控功能,能够根据攀爬车的传达模式作出适当的调整。使用 2.4 GHz FASST 技术!详细资料在本文内。Futaba have released the T3PM, a three-channel pistol-grip computer system for RC model car and racing boat drivers, in 2.4 GHz FASST technology, a spread spectrum system with permanent frequency hopping (FHSS). This New variant of the T3PM system now has a crawler mixer function for trial vehicles for four-wheel-steering. Depending on what is required for the terrain, a mixer function allows the front and rear axles to be articulated in the same or in opposite directions. Modern casing design with ergonomically positioned controls and setup elements. Large 100-segment LCD screen to provide a clear display of function settings. 10 saved models in memory, with model name, copy model and model reset, for easy management of different models. 4 digital keyboard keys and handle button for setting up trimming and mixer functions, including while driving. ABS-cadence brakes for optimum grip when braking in curves. A function called drive condition, allows a second setting to be called up for the functions which are to be adjusted during a race.【大力电子】Futaba T3PM 攀爬车遥控器 遥控器,FUTABA,遥控车 作者:沈淼章 7194 【大力电子】Futaba T3PM 攀爬车遥控器 遥控器,FUTABA,遥控车 作者:沈淼章 7865
General: - Servo path setting for throttle, steering and 3rd channel - Servo reversal, steering, throttle, 3rd channel - Trim - Steering servo speed - Exponential steering function - Exponential throttle function - ABS-Cadence brake - Throttle acceleration - Brakes mixer, front and/or rear brakes - Brakes path setting - Programmable mixer - Fail-Safe setting - Timer settings - Stopwatch reset - Setting 3rd channel, separate or brakes channel
Specification: Dimensions: 210 x 180 x 90 mm Weight: 652 g Frequency band: 2.40 Power Supply: 9,6…12V Transmission system: FSK, HRS-FSK Functions: 6/3 Servos【大力电子】Futaba T3PM 攀爬车遥控器 遥控器,FUTABA,遥控车 作者:沈淼章 6451 Source: Robitronic [robitronic.com]
发表于 2014-4-12 22:08:30 | 显示全部楼层
明天更快乐能多点图片吗
发表于 2014-4-13 16:28:01 | 显示全部楼层
沈淼章顶你哈哈
发表于 2014-4-14 10:17:48 | 显示全部楼层
李俊顶你到天亮
发表于 2014-4-15 01:18:39 | 显示全部楼层
水上不错
