657查看 | 8回复
【大力电子】Futaba HS系列高速接收機
发表于 2014-4-9 21:00:19 | 显示全部楼层 |阅读模式
R6008HS 8-Channel Receiver
  • Offers 2048 resolution plus FASST benefits including Dual Antenna Diversity and significantly reduced latency for lightning-quick response
  • High-speed operation takes advantage of digital servos’ ability to update more rapidly than analog servos (both can be used with this receiver)
  • HS (High Speed) mode improves frame rate on channels 1-6 to only 7 milliseconds — compared to 14 milliseconds at normal mode.** Note: In HS mode, digital servos (including those in the BLS series) must be used on channels 1-6. Those channels will also operate gyros and brushless ESCs. Channels 7 and 8 continue at normal mode and accept any servos.
Stock #DimensionsWeight
FUTL76391.8 x 0.9 x 0.5 in (45 x 22 x 13 mm)0.48 oz (13.54 g)
【大力电子】Futaba HS系列高速接收機 FUTABA,futaba6208接收机 作者:沈淼章 5732
R6014FS Receiver
  • True, 14-channel design.
  • Designed specifically for FASST™ 2.4GHz systems.
  • Push-button Easy-Link™ feature locks receiver to the transmitter’s unique signal.
  • Includes battery fail-safe with auto cut-off and setup LED.
FUTL76451.5 x 2.1 x 0.6 in (38 x 52 x 16 mm)0.76 oz (21.5 g)
【大力电子】Futaba HS系列高速接收機 FUTABA,futaba6208接收机 作者:沈淼章 9441
发表于 2014-4-10 06:34:22 | 显示全部楼层
gopro学习了
发表于 2014-4-10 06:34:36 | 显示全部楼层
蒙在股里能多点图片吗
发表于 2014-4-11 00:59:51 | 显示全部楼层
爱飞帮顶
发表于 2014-4-11 01:02:42 | 显示全部楼层
老刘的烦恼能在详细点吗
发表于 2014-4-11 21:31:56 | 显示全部楼层
;P
发表于 2014-4-11 21:32:08 | 显示全部楼层
沈淼章谢谢分享
活着的死人 该用户已被删除
发表于 2014-4-12 14:56:22 | 显示全部楼层
发表于 2014-4-12 14:57:32 | 显示全部楼层
沈淼章谢谢分享
