646查看 | 6回复
【大力电子】Futaba FF10G 2.4G功能詳解
发表于 2014-4-9 20:56:18 | 显示全部楼层 |阅读模式
【大力电子】Futaba FF10G 2.4G功能詳解 FUTABA,EPO,futaba14sg和t8fg 作者:沈淼章 1234
[size=0.83em]2012-3-22 16:59 上傳
下載附件 [size=0.83em](66.91 KB)
10-Channel 2.4GHz Computer System The 10CG: pro-level features at a sport-system price. The 10CG is perfect for the price-conscious pilot — an integrated, 2.4GHz treasure trove of features formerly found only on the most advanced Futaba systems. But it’s also a system that boasts advantages few others can claim: 7-point throttle and pitch curves; 4 heli flight modes; a round dozen factory-defined glider mixes; graphics for programming swash plate types; swash ring; and logic switches that allow you to activate a timer or other function just by changing the positions of specific sticks or switches.
Video 【大力电子】Futaba FF10G 2.4G功能詳解 FUTABA,EPO,futaba14sg和t8fg 作者:沈淼章 8900
10CG System Overview: Dial ‘n Key™ programming w/joystick Airplane, heli and glider software 2048 resolution Real-Time Response™ Smart Switch Technology™ Basic & advanced menus 15-model memory, expandable to 48 models* 10-character model & user naming Assignable switches & dials/functions Model select, copy, re-set Data transfer 2 proportional slider switches Fail-safe, sub-trims, servo reversing & EPA Digital trims & trim step, expo & dual/triple rates 160 x 72 backlit LCD w/adjustable contrast Servo monitor display Auxiliary channel screen for 1-step function/switch assignment Model & system timers Full functionality trainer system (cord required) Throttle cut, hold & idle down Mode 1-4 selectable Sticks w/length and tension adjustments * Requires optional 128K CAMPac Module (FUTM9408) Airplane Features 8 programmable mixes Elevator/Flap Throttle needle Aileron differential Flaperons V-tail Elevon Air brake w/elevator delay Ailevator 4-position snap roll switch 2 independent gyro settings 7-point throttle curve Flap trim Heli Features 6 programmable mixes Hover/pitch Hover throttle 8 swash plate types w/graphics Swash AFR 5-point revo mixing Gyro menu 7-point throttle & pitch curves w/delay High/low pitch setting Swash ring Throttle hold & 3 idle-ups w/delay Glider Features 8 programmable mixes Butterfly/elevator (2) Elevator/flap Chamber mix Aileron/flap Aileron/rudder Flaperons V-tail 4-point offset Spoiler mix Single/dual flap servos 5 flight conditions 3 wing types Adjustable motor cut
R6014FS Receiver True, 14-channel design. Designed specifically for FASST™ 2.4GHz systems. Push-button Easy-Link™ feature locks receiver to the transmitter’s unique signal. Includes battery fail-safe with auto cut-off and setup LED.
【大力电子】Futaba FF10G 2.4G功能詳解 FUTABA,EPO,futaba14sg和t8fg 作者:沈淼章 7484
【大力电子】Futaba FF10G 2.4G功能詳解 FUTABA,EPO,futaba14sg和t8fg 作者:沈淼章 5845
发表于 2014-4-9 21:23:31 | 显示全部楼层
风情顶你到天亮
发表于 2014-4-10 15:39:30 | 显示全部楼层
理想希望多多分享
发表于 2014-4-11 08:52:02 | 显示全部楼层
沈淼章谢谢分享
小鱼 该用户已被删除
发表于 2014-4-11 08:53:03 | 显示全部楼层
发表于 2014-4-12 02:08:19 | 显示全部楼层
沈淼章顶你哈哈
发表于 2014-4-12 02:08:53 | 显示全部楼层
飞哥帮顶
