2011查看 | 8回复
【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址)
发表于 2019-4-16 14:27:05 | 显示全部楼层 |阅读模式
更新真快,10.5.1~!
【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:宿宿-墨墨他爹 4855
@mikeller mikeller released this 3 days ago · 11 commits to master since this release
Important
Betaflight Configurator 10.5.1 was released to fix a bug in 10.5.0 that affects Mac OS only, preventing flashing of firmware on this platform.
Which file do I need?
Windows (7, 8, 10): betaflight-configurator-installer_<version>_win32.exe;
Mac OS X: betaflight-configurator_<version>_macOS.dmg;
Linux: betaflight-configurator_<version>_amd64.deb (Ubuntu, debian), betaflight-configurator-<version>.x86_64.rpm (Red Hat, Fedora, CentOS), betaflight-configurator_<version>_linux64.zip(others).
Release Notes
This release contains all of the changes necessary to support version 4.0 of the Betaflight firmware. If you are using firmware 4.0, it is essential that you upgrade to this version, in order to get support for configuring the new features of 4.0.
In addition to this we have made the following improvements:
If your platform is not supported, but can run a recent version of Chrome, please follow these instructions to install the Betaflight Configurator from the Chrome web store.
We have tried to make this release as bug free as possible. If you still find a bug, please report it back to us by opening an issue here.
If you want to talk about Betaflight, ask configuration questions, or just hang out with fellow pilots, you can do this in our Facebook group.
Betaflight also has a presence in the Slack messaging platform. Register here, and then come join us in Slack. Most developers hang out there, so this is a great place to talk about the things you are tinkering with in Betaflight, or get help with really complicated configuration problems.
Fixes:
fixed header bar wrapping on small screens;
fixed the PID tab layout;
various other UI fixes.
New GUI support for the following firmware features:
OSD profile configuration / selection;
extended logic (AND, coupling of modes) for Modes tab;
GPS rescue;
D min;
integrated yaw;
dynamic gyro and D Term low pass filters;
multi gyro configuration;
throttle limit;
new OSD display / statistics elements.
Improvements:
direct access to firmware flasher from the header bar;
switched GPS tab from Google Maps to OpenStreetMap;
'Reset Output' and 'Copy To Clipboard' buttons and coloured error messages in the CLI tab;
check selected device before rebooting into mass storage device mode;
improved drag / drop for OSD elements.
New Languages:
Svenska (Swedish);
Русский язык (Russian);
Bahasa Indonesia (Indonesian).
下载地址在这里
https://github.com/betaflight/betaflight-configurator/releases
云在这里有
https://mp.weixin.qq.com/s/Pve2FxPUUStijUwqUTVscw
发表于 2019-4-16 20:04:10 | 显示全部楼层
顶一个【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:wyd1996 8490 【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:wyd1996 3994 【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:wyd1996 1325
发表于 2019-4-16 20:09:04 | 显示全部楼层
【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:昶平 5105 【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:昶平 9768 【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:昶平 7217 【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:昶平 2177 【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:昶平 3399
发表于 2019-4-17 09:16:11 | 显示全部楼层
更新这么快看来有bug
发表于 2019-4-17 10:03:59 | 显示全部楼层
不知道为什么10.5.1会报病毒,10.5.0就不会
发表于 2019-4-18 19:34:26 | 显示全部楼层
【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:a843001 1989 【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:a843001 2189 【他爹】又更新啦~!10.5.1地面站正式中文版(附下载地址) 地面站,GPS,betaflight 作者:a843001 7544 {:1_3:}{:1_3:}{:1_3:}{:1_3:}{:1_3:}{:1_3:}
发表于 2019-4-19 21:37:44 | 显示全部楼层
是会报病毒,但这不是关键,
4.0,解锁电机就怠速自转,设置了也一样,
只能双刷回来了
发表于 2019-4-22 15:44:11 | 显示全部楼层
我是真的看不明白
