1341查看 | 8回复
|bunnyAAT|图纸代码全开源|AAT的另一种思路
发表于 2018-9-12 20:27:39 | 显示全部楼层 |阅读模式
github我的repo里有一切需要的东西 https://github.com/ErcBunny/bunnyAAT ,更多的细节可以参考航吧http://tieba.baidu.com/p/5811562128 。请各位大佬提出宝贵的建议!
# bunnyAAT v0.0.2b
0) PREFACE
  I know it is strange that this repo starts with v0.0.2b. Well, the earlier versions can be found at tieba. And if you read Chinese you'll know more details about this project, which is not necessary at all since the best part (so far) is posted here at github.
1) HARDWARE SETUP
  In "hardware" folder you can find autocad blueprints (.dwg) and schematic diagrames.
  Read the schematic diagrams and you will know what boards and sensors to buy.
  "3mm.dwg" illustrates additional parts needed to complete the structure of the antenna tracker and also the payload adapter for blacksheep  quadcopter airframe, which is shown in "blacksheep.dwg".
  "adapter.dwg" is only useful if you want to use the 23dbi MFD antenna. Otherwise you can simply glue your antenna to the moving part.
  "base.dwg" shows you what bunnyAAT looks like. Most of its parts are bought online. One possible version of the base can be found here: https://item.taobao.com/item.htm?spm=a1z09.2.0.0.28812e8dhvkkIb&id=37631042726&_u=a2ndlmbi166b.
  Also, it is recommended to cover the baro_sensor with a sponge and a reflective surface at the top. By doing this, we can increase sensing accuracy (but only a bit).
2) ABOUT SOFTWARE
  There are two apps for android. One of the two is magvar.apk. This app connects automatically to https://www.ngdc.noaa.gov/geomag-web/#declination. By enabling the positioning service the app will return the declination value of your location. The other one is terminal.apk. It is a bluetooth terminal with macro buttons which displays aircraft status and voltage of batteries.
  "mwc.ino" should be uploaded into the mwc flight controller board (make sure that your flight controller uses BMP180 and MPU6050, otherwise you need to modify the code). "servo.ino" should be uploaded into another pro mini board. In order to upload sketches you may need the FTDI USB to TTL tool and corresponding driver.
  "uno.ino" is for the uno board installed on your aircraft.
3) CONFIGURATION
  Change gps refresh rate to 5hz or higher.
  Edit macro buttons in the terminal app. '0' must be set as "continue" and '_local declination value_' is recommended to be set as "default".
  Turn your tracker into debug mode by uncommenting the the first line of "mwc.ino" and put your aircraft at the same height as the antenna. Follow the instructions. When you reach the stage of calibrating the mag_sensor, the tracker should spin clockwise. If not, swap the values of LEFT and RIGHT in line 2 and 4. And if the pan servo doesn't stop, modify the STOP value too. The debug mode returns two statements "#define offAlt _value_" and "#define K _value_". Modify the values in line 5 and 6 then comment line 1 and upload. Now you are good to go.
  When the the aircraft and AAT are exposed to direct sunlight, the baro_sensors are very likely to be affected. That is, the value returned in debug mode is not accurate anymore. You need to redo debugging or adjust the offAlt value after estimating the error.
  The last thing. You may notice that the V_air and V_gnd is really off the track. Therefore, in "mwc.ino" and "uno.ino" you can find "#define offV", which enables you to calibrate the value by hand. For example, if V_gnd is 3.7 displayed in terminal, while its real value is 4.0, then I'll enter "#define offV 0.3 (4.0 - 3.7)".
4) CREDITS
  Libraries are very helpful. I saved a lot of time by using them. I'd like to thank contributors who uploaded their libraries.
  I don't quite understand how a kalman filter works (just for now), so the code for this part is written by Similar_Fair. Click the link below for more information: https://blog.csdn.net/sunhaobo1996/article/details/53861752.
发表于 2018-9-12 23:38:07 | 显示全部楼层
发表于 2018-9-13 08:41:43 | 显示全部楼层
发表于 2018-9-13 11:06:32 | 显示全部楼层
 楼主| 发表于 2018-9-13 19:58:34 | 显示全部楼层
自顶,请问各位大佬怎么对apm进行二次开发,我想把我的代码加在飞控身上就不用多背一块单片机和传感器在天上跑了
发表于 2018-9-14 10:12:20 | 显示全部楼层
来看一下,不错
发表于 2018-9-17 10:16:06 | 显示全部楼层
楼主思路根我类似,我是在原来开源的舵机版AAT基础上进行了大改,通过蓝牙连接手机APP,使用手机APP的GPS数据作为家的数据,回传的GPS数据在APP中显示飞机的位置。可以直接通过APP进行调参。
这里是模拟测试的视频:
https://www.bilibili.com/video/av31897946/
发表于 2018-9-17 10:55:24 | 显示全部楼层
