740查看 | 6回复
APM飞控日志求分析
发表于 2018-5-19 23:34:56 | 显示全部楼层 |阅读模式
小弟今晚一部一部的来按照教程,校准了所有东西
起飞了不倒了。不猛飘了,但是猛窜高窜低了然后抽搐了一下,然后又继续飞,留待模式直接冲过去了。唉
哪位大佬帮忙分析下日志看看怎么回事。小弟奉上2个飞行日志然后其中最长飞行的日志用APM飞行日志分析软件分析出来一堆的东西
APM Log File Analiser v2.2.2.1
Log FileName: D:\航模\飞控\MP地面站调惨软件\免安装绿色版MissionPlanner-1.3.28\logs\QUADROTOR\1\2018-05-19 22-33-27.log
Ardu Version: V3.2.1 Build:
    Ardu Type: APM:Copter
   FC Version: 0
FC Frequency: 100Hz
   Frame Type: X
Data Found in APM Log File:-
IMU, GPS, CTUN, PM, CURR, NTUN, MSG, CMD, ATT, MODE, EV, DU32, ERR, BARO
Data NOT Found in APM Log File:-
ATUN, ATDE, MOT, OF, MAG, INAV, STRT, D16, DU16, D32, DFLT, PID, CAM, GPS2, IMU2, IMU3, MAG2, MAG3, AHR2, EKF1, EKF2, EKF3, EKF4, TERR, UBX1, UBX2, RCIN, RCOU, POWR, RAD, SIM
FAILSAFE SETTINGS:
  Main Battery = Not Activated
Ground Control = Activated, with always RTL
      Receiver = Not Activated
     GEO Fence = Parameter Not Found in Log
ERROR: 1 FailSafe Setup errors have been found - DO NOT FLY!
PARAMETER ISSUES:-
TUNE = 0
Information: CH6 Tuning is Disabled
WARNING: Curruption Of FMT Lines Detected!
WARNING: the Analyzer tried to handle them.
WARNING: This is a v3.2 firmware issue that has been reported!
06/01/1980 - 000314: Mode Changed to Stabilize
06/01/1980 - 000314: Mode Initialised at 0 0 Alt: 0 Spd:0
06/01/1980 - 000315: Armed
Limited Data Available - Mode Ignored
06/01/1980 - 000316: Mode Changed to Stabilize
06/01/1980 - 000316: Mode Initialised at 0 0 Alt: 0 Spd:0
19/05/2018 14:33:43 - 000321: Take Off
19/05/2018 14:33:43 - 000321: Mode Time Changed to 19/05/2018 14:33:43
19/05/2018 14:33:43 - 000326: APM Information: Home is NOT Set
19/05/2018 14:33:43 - 000326: Simple Mode is Disabled
19/05/2018 14:33:43 - 000326: APM Information: RC Pre-Arm checks have been completed.
19/05/2018 14:33:43 - 000326: APM Information: All Pre-Arm checks have been completed.
19/05/2018 14:33:43 - 000326: APM Information: USB is NOT Connected.
19/05/2018 14:33:43 - 000326: Rx Information: CH7 Switch is High.
19/05/2018 14:33:43 - 000326: Rx Information: CH7 function: Disabled
19/05/2018 14:33:43 - 000326: Rx Information: CH8 Switch is Centred.
19/05/2018 14:33:43 - 000326: Rx Information: CH8 function: Disabled
19/05/2018 14:33:43 - 000326: DU32 Landing Detected.
19/05/2018 14:33:43 - 000326: APM Information: PWM is present.
19/05/2018 14:33:43 - 000328: FC Performance Warning: The number of long running loops is 11%
19/05/2018 14:33:43 - 000328: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:33:43 - 000410: Auto Mode is waiting for Throttle.
19/05/2018 14:33:49 - 000752: SET_HOME
19/05/2018 14:33:49 - 000754: GPS ERROR: GPS lock lost for at least 5 seconds.
19/05/2018 14:33:49 - 000828: GPS ERROR: GPS lock restored.
19/05/2018 14:33:49 - 000830: APM Information: Home is Set
19/05/2018 14:33:54 - 001165: FC Performance Warning: The number of long running loops is 11.3%
19/05/2018 14:33:54 - 001165: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:33:55 - 001210: GPS ERROR: GPS Glitch.
19/05/2018 14:33:55 - 001259: GPS ERROR: GPS Glitch Cleared.
19/05/2018 14:34:05 - 002022: FC Performance Warning: The number of long running loops is 11%
19/05/2018 14:34:05 - 002022: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:34:16 - 002884: FC Performance Warning: The number of long running loops is 11.8%
19/05/2018 14:34:16 - 002884: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:34:18 - 003093: Armed
       Alt(m ~ ft)   Spd(m/s ~ mph)   Dist(km ~ mi)     Launch(m ~ ft)    GPS-Sats   GPS-Hdop    Eff(mA/min)
Max      6 ~ 19          2 ~ 4         0.04 ~ 0.02      22.51 ~ 73.84       11        5.25           N/A
Avg      1 ~ 3           0 ~ 0          N/A ~ N/A         N/A ~ N/A          9        2.51           ~~~
Min     -2 ~ -7          0 ~ 0          N/A ~ N/A        0.39 ~ 1.28         7        1.71           N/A
Stabilize Flight Time (Session)= 35 seconds, 0:35
Stabilize Flight Time   (Total)= 35 seconds, 0:35
Warning: Less than 9 Satellites was detected during this mode.
19/05/2018 14:34:18 - 003094: Mode Changed to Stabilize
19/05/2018 14:34:18 - 003094: Mode Initialised at 22.9965474 113.1184304 Alt: -0.35 Spd:0.01
19/05/2018 14:34:42 - 003112: DU32 Landing Detected.
Max      0 ~ 0           0 ~ 0         0.00 ~ 0.00      18.72 ~ 61.41       10        2.41           N/A
Avg      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A         10        2.41           ~~~
Min      0 ~ 0           0 ~ 0          N/A ~ N/A       18.63 ~ 61.14       10        2.41           N/A
Stabilize Flight Time (Session)= 25 seconds, 0:25
Stabilize Flight Time   (Total)= 60 seconds, 1:00
WARNING: A HDop of greater than 2 was detected during this mode.
19/05/2018 14:34:44 - 003255: Mode Changed to Loiter
19/05/2018 14:34:44 - 003255: Mode Initialised at 22.9965641 113.1184012 Alt: 0.19 Spd:0.04
19/05/2018 14:34:46 - 003488: Auto Mode is waiting for Throttle.
19/05/2018 14:34:48 - 003684: FC Performance Warning: The number of long running loops is 11.4%
19/05/2018 14:34:48 - 003684: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:34:56 - 004342: LAND_COMPLETE_MAYBE
19/05/2018 14:34:57 - 004415: Landed
Max      1 ~ 3           0 ~ 0         0.00 ~ 0.00      20.31 ~ 66.65       10        3.35           N/A
Avg      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A          8        3.24           ~~~
Min     -1 ~ -4          0 ~ 0          N/A ~ N/A       18.73 ~ 61.47        8        2.41           N/A
Loiter Flight Time (Session)= 13 seconds, 0:13
Loiter Flight Time   (Total)= 13 seconds, 0:13
19/05/2018 14:34:57 - 004437: DU32 Landing Detected.
19/05/2018 14:34:59 - 004630: FC Performance Warning: The number of long running loops is 11.4%
19/05/2018 14:34:59 - 004630: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:35:10 - 005589: FC Performance Warning: The number of long running loops is 11.6%
19/05/2018 14:35:10 - 005589: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:35:11 - 005675: NOT_LANDED
19/05/2018 14:35:22 - 006480: FC Performance Warning: The number of long running loops is 11.4%
19/05/2018 14:35:22 - 006480: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:35:25 - 006725: LAND_COMPLETE_MAYBE
19/05/2018 14:35:26 - 006852: DU32 Landing Detected.
19/05/2018 14:35:30 - 007235: Armed
19/05/2018 14:35:30 - 007236: Mode Changed to Stabilize
19/05/2018 14:35:30 - 007236: Mode Initialised at 22.9964963 113.1183963 Alt: 0.26 Spd:0.02
19/05/2018 14:35:44 - 007272: FC Performance Warning: The number of long running loops is 11.4%
19/05/2018 14:35:44 - 007272: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:35:45 - 007367: Take Off
19/05/2018 14:35:46 - 007452: Auto Mode is waiting for Throttle.
Max      1 ~ 3           1 ~ 2         0.01 ~ 0.01      28.66 ~ 94.02       12        3.47           N/A
Avg      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A         10        2.81           ~~~
Min      0 ~ 0           0 ~ 0          N/A ~ N/A       24.76 ~ 81.22        9        2.17           N/A
Stabilize Flight Time (Session)= 9 seconds, 0:09
Stabilize Flight Time   (Total)= 69 seconds, 1:09
19/05/2018 14:35:54 - 008087: Mode Changed to Loiter
19/05/2018 14:35:54 - 008087: Mode Initialised at 22.9964728 113.1183979 Alt: 0.97 Spd:0.78
19/05/2018 14:35:55 - 008131: FC Performance Warning: The number of long running loops is 11.78821%
19/05/2018 14:35:55 - 008131: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
Max      1 ~ 3           1 ~ 2         0.00 ~ 0.00      29.58 ~ 97.06       11         4.1           N/A
Avg      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A          9        3.10           ~~~
Min      0 ~ 0           0 ~ 0          N/A ~ N/A       28.71 ~ 94.19        8        2.54           N/A
Loiter Flight Time (Session)= 8 seconds, 0:08
Loiter Flight Time   (Total)= 21 seconds, 0:21
19/05/2018 14:36:03 - 008753: Mode Changed to Stabilize
19/05/2018 14:36:03 - 008753: Mode Initialised at 22.9964704 113.1184094 Alt: -0.11 Spd:0.06
19/05/2018 14:36:03 - 008785: LAND_COMPLETE_MAYBE
19/05/2018 14:36:04 - 008859: Landed
Max      0 ~ 0           0 ~ 0         0.00 ~ 0.00      28.66 ~ 94.04       11        2.54           N/A
Avg      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A         11        2.54           ~~~
Min      0 ~ 0           0 ~ 0          N/A ~ N/A       28.41 ~ 93.21       11        2.54           N/A
Stabilize Flight Time (Session)= 1 seconds, 0:01
Stabilize Flight Time   (Total)= 70 seconds, 1:10
19/05/2018 14:36:04 - 008865: Take Off
19/05/2018 14:36:05 - 008916: Auto Mode is waiting for Throttle.
19/05/2018 14:36:05 - 008916: DU32 Landing Detected.
19/05/2018 14:36:06 - 008996: FC Performance Warning: The number of long running loops is 11.5%
19/05/2018 14:36:06 - 008996: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
Max      3 ~ 9           2 ~ 4         0.00 ~ 0.00      28.36 ~ 93.06       11        4.12           N/A
Avg      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A         10        2.92           ~~~
Min      0 ~ 0           0 ~ 0          N/A ~ N/A       26.31 ~ 86.32        8        2.54           N/A
Stabilize Flight Time (Session)= 6 seconds, 0:06
Stabilize Flight Time   (Total)= 76 seconds, 1:16
19/05/2018 14:36:11 - 009399: Mode Changed to Loiter
19/05/2018 14:36:11 - 009399: Mode Initialised at 22.9964888 113.1184565 Alt: 3.02 Spd:1.62
Max      5 ~ 16          1 ~ 2         0.00 ~ 0.00      26.88 ~ 88.18       12        3.49           N/A
Avg      4 ~ 13          0 ~ 0          N/A ~ N/A         N/A ~ N/A         10        2.75           ~~~
Min      3 ~ 9           0 ~ 0          N/A ~ N/A       25.56 ~ 83.85        9        2.31           N/A
Loiter Flight Time (Session)= 4 seconds, 0:04
Loiter Flight Time   (Total)= 25 seconds, 0:25
19/05/2018 14:36:15 - 009736: Mode Changed to Stabilize
19/05/2018 14:36:15 - 009736: Mode Initialised at 22.9964871 113.1184899 Alt: 4.82 Spd:1.16
19/05/2018 14:36:17 - 009876: FC Performance Warning: The number of long running loops is 11.4%
19/05/2018 14:36:17 - 009876: FC Performance Warning: This level is not classed as serious and one off reports can be ignored.
19/05/2018 14:36:18 - 009976: Auto Mode is waiting for Throttle.
Overall Flight Summary:
Max      6 ~ 19    18498360 ~ 41379652    0.07 ~ 0.04      29.58 ~ 97.06       12        5.25
Avg      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A          9        2.77
Min      0 ~ 0           0 ~ 0          N/A ~ N/A         N/A ~ N/A          8        1.64
WARNING: Less than 9 Satellites was detected during this mode.
Flight Controller Performance Summary:
          Freq(Hz)     LongLoops(%)   LongLoop(ms)    Analyser Evaluation
Avg         100          11.45            32.32                Overloaded
Information: Non-Default HW Frequency detected, Analyser Evaluation may be effected.
Power Summary:
       Battery(V)        Vcc(V)        Current(A)        Cap(mAh)        Used Cap(mAh)    Eff(mA/mim)    Max Fly 80%(mins)
Max        0.00           5.05             0.00             3300                0             N/A              N/A
Min        0.00           5.01           999.99             3300              N/A             N/A              N/A
  Overall Flight Time = 111 seconds, 1:51
APM Information: Current Sensing is disabled.
*** Vibration Analysis has been removed from v2.2 onwards, you should now
*** review the "Vibration Graph" instead to understand your levels of vibration.
奉上三个飞行日志求帮忙拜托各位了
日志压缩包.rar
551.1 KB, 下载次数: 5, 下载积分: 牛币 -10
发表于 2018-5-20 00:23:23 | 显示全部楼层
重新自动调PID还不行吗
 楼主| 发表于 2018-5-20 00:43:34 | 显示全部楼层
朱启宋 发表于 2018-5-20 00:23 APM飞控日志求分析 飞控,地面站,APM,GPS,pixhawk飞控 作者:大帝小白 9183
重新自动调PID还不行吗
稳定都不稳定怎么自动调参?
发表于 2018-5-20 06:24:14 | 显示全部楼层
进来学习,正在组装APM,
发表于 2018-5-20 10:09:26 | 显示全部楼层
不懂顶顶顶
发表于 2018-5-21 07:30:49 | 显示全部楼层
刷个其他版本固件试试
