720查看 | 1回复
飞机解锁报错
发表于 2018-4-11 11:21:30 | 显示全部楼层 |阅读模式
发表于 2018-4-11 11:21:31 | 显示全部楼层
The vehicle must have a good position estimate (LEDs should be green) when the rover is armed or SmartRTL will be disabled. If the vehicle is armed without a good position estimate, "SmartRTL deactivated: bad position" will be sent to the ground station.
你没有接GPS 或者GPS没信号
回复
