小火箭 发表于 2017-8-27 11:02:22
stc12c5a ADC修改串口波特率
在修改串口波特率这一块总是改不对,我用的波特率计算器,12Mhz,9600,求大神帮忙解决
/* --- STC12C5Axx Series MCU A/D Conversion Demo -------------------*/
/* --- Mobile: (86)13922805190 -------------------------------------*/
/* --- Fax: 86-0513-55012956,55012947,55012969 ---------------------*/
/* --- Tel: 86-0513-55012928,55012929,55012966----------------------*/
/* --- Web: www.STCMCU.com -----------------------------------------*/
/* --- Web: www.GXWMCU.com -----------------------------------------*/
#include "reg51.h"
#include "intrins.h"
#define FOSC    11059200L
#define BAUD    9600
typedef unsigned char BYTE;
typedef unsigned int WORD;
/*Declare SFR associated with the ADC */
sfr ADC_CONTR   =   0xBC;         //ADC control register
sfr ADC_RES   =   0xBD;         //ADC high 8-bit result register
sfr ADC_LOW2    =   0xBE;         //ADC low 2-bit result register
sfr P1ASF       =   0x9D;         //P1 secondary function control register
/*Define ADC operation const for ADC_CONTR*/
#define ADC_POWER   0x80            //ADC power control bit
#define ADC_FLAG    0x10            //ADC complete flag
#define ADC_START   0x08            //ADC start control bit
#define ADC_SPEEDLL 0x00            //420 clocks
#define ADC_SPEEDL0x20            //280 clocks
#define ADC_SPEEDH0x40            //140 clocks
#define ADC_SPEEDHH 0x60            //70 clocks
void InitUart();
void InitADC();
void SendData(BYTE dat);
BYTE GetADCResult(BYTE ch);
void Delay(WORD n);
void ShowResult(BYTE ch);
void main()
    InitUart();                     //Init UART, use to show ADC result
    InitADC();                      //Init ADC sfr
    while (1)
      ShowResult(0);            //Show Channel0
      ShowResult(1);            //Show Channel1
      ShowResult(2);            //Show Channel2
      ShowResult(3);            //Show Channel3
      ShowResult(4);            //Show Channel4
      ShowResult(5);            //Show Channel5
      ShowResult(6);            //Show Channel6
      ShowResult(7);            //Show Channel7
Send ADC result to UART
    SendData(ch);                   //Show Channel NO.
    SendData(GetADCResult(ch));   //Show ADC high 8-bit result
//if you want show 10-bit result, uncomment next line
//    SendData(ADC_LOW2);             //Show ADC low 2-bit result
Get ADC result
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
    _nop_();                        //Must wait before inquiry
    _nop_();
    _nop_();
    _nop_();
    while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
    ADC_CONTR &= ~ADC_FLAG;         //Close ADC
    return ADC_RES;               //Return ADC result
Initial UART
void InitUart()
    SCON = 0x5a;                  //8 bit data ,no parity bit
    TMOD = 0x20;                  //T1 as 8-bit auto reload
    TH1 = TL1 = 0xFD; //Set Uart baudrate
    TR1 = 1;                        //T1 start running
Initial ADC sfr
void InitADC()
    P1ASF = 0xff;                   //Open 8 channels ADC function
    ADC_RES = 0;                  //Clear previous result
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
    Delay(2);                     //ADC power-on and delay
Send one byte data to PC
Input: dat (UART data)
Output:-
    while (!TI);                  //Wait for the previous data is sent
    TI = 0;                         //Clear TI flag
    SBUF = dat;                     //Send current data
Software delay function
void Delay(WORD n)
    WORD x;
    while (n--)
      x = 5000;
      while (x--);
飞越天际线 发表于 2017-8-27 15:09:48
看不懂,哈哈{:1_9:}
查看完整版本: stc12c5a ADC修改串口波特率
