电流计与电压计
电流计电压计的使用及说明?谢谢
Thank you very much , i love you , we all frends!! 电流电压计使用按照说明接线就好,接线端子都是按照标准出厂做好的,买的时候选择APM版或者PIX版,关键在地面站电池检测里选择合适的参数选项,符合3DR电源标准的模块不需要校准电压,直接选择4 4第三项根据飞控版本选择,非标准的需要选择4 0 版本代号,同时用精准的万用表测量电池实际电压填到下方测量电池电压框内。
Current and voltage meter used in accordance with the instructions like wiring, the terminal is in accordance with the standard factory to do a good job, when buying APM version or PIX version, the key in the ground station battery detection, select the appropriate parameter options, in line with 3DR power standard module No need to calibrate the voltage, the direct choice of 4 4 The third item according to the flight control version selection, non-standard need to select the 40 version of the code, while the precise multimeter to measure the actual battery voltage to the bottom of the measurement battery voltage box.
系统故障通知:使用电脑登录论坛,图片上传功能故障,造成时而图片上传不上去,时而可以上传,给大家发帖带来不便,技术人员正在寻找原因。会员们可以下载手机app发图可以正常使用!给大家带来不便,在此道歉了!我们正在努力! 中英文的答案,楼主人缘好啊!
