羡慕许仙曰过蛇 发表于 2017-2-10 10:31:38
基于intel Curie的开源机械臂(转帖)
喜欢就支持下这个项目吧: http://www.kenrobot.com/arduinocn/vote参赛编号13
基于intel Curie的机械臂具有动作记忆功能,通过记录每个点的位置,依次去回放动作,达到对机械臂编程的作用。机械臂的是用方法是:
1.DC及USB均上电,上电后并成功启动后LED会闪一下白光。2.成功启动后手拧电位器可以看到机械抓的开合。
试教步骤
1.    掰动机械臂到需要的位置后轻触一下按键,等待LED闪烁两次红色表示该位置已记录完毕。2.    依上述方法掰动几次机械臂完成录入时长按按键1秒以上,松开按键后LED闪烁两次蓝色表示录入结束开始自动执行记录动作程序。3.    需要停止重新录入动作时,长按按键1秒以上,松开按键后LED闪烁两次蓝色表示可以重新录入动作。
目前,机械臂的模型和代码都还在优化阶段,等成熟后,计划可以推出机械臂套件出售,下面是目前已经修改的模型特征目前SW的工程文件我已经上传,大家可以提出自己的宝贵意见,如果有更好的制作方案,欢迎提出交流。
机械臂视频:
模型stl文件:ARM_PRINTABLE.zip (423.23 KB, 下载次数: 153)
co#include #include
Servo myservo0,myservo1,myservo2,myservo3,myservo4;// create servo object to control a servo
                // twelve servo objects can be created on most boards
int addr = 0;
int pos = 0;    // variable to store the servo position
int read_Servo0, read_Servo1, read_Servo2, read_Servo3, read_Servo4;
bool bottom = false;
bool bottom_pressed = false;
int min_0, max_0, min_1, max_1, min_2, max_2, min_3, max_3;
//int R_PIN, G_PIN, B_PIN;
#define R_PIN4
#define G_PIN5
#define B_PIN6
bool eeprom_end()
      if (EEPROM.read(addr) == 6666) {
                delay(100);
                return false;
      else
                return true;
bool match_servo()
      int read_Servo0_p, read_Servo1_p, read_Servo2_p, read_Servo3_p, read_Servo4_p;
      read_Servo0_p = analogRead(A0);
      if (read_Servo0_p > max_0)
                read_Servo0_p = max_0;
      if (read_Servo0_p < min_0)
                read_Servo0_p = min_0;
      read_Servo0_p = map(read_Servo0_p, min_0, max_0, 611, 2389);
      read_Servo1_p = analogRead(A1);
      if (read_Servo1_p > max_1)
                read_Servo1_p = max_1;
      if (read_Servo1_p < min_1)
                read_Servo1_p = min_1;
      read_Servo1_p = map(read_Servo1_p, min_1, max_1, 611, 2389);
      read_Servo2_p = analogRead(A2);
      if (read_Servo2_p > max_2)
                read_Servo2_p = max_2;
      if (read_Servo2_p < min_2)
                read_Servo2_p = min_2;
      read_Servo2_p = map(read_Servo2_p, min_2, max_2, 611, 2389);
      read_Servo3_p = analogRead(A3);
      if (read_Servo3_p > max_3)
                read_Servo3_p = max_3;
      if (read_Servo3_p < min_3)
                read_Servo3_p = min_3;
      read_Servo3_p = map(read_Servo3_p, min_3, max_3, 611, 2389);
      read_Servo4_p = analogRead(A4);
      if (read_Servo4_p > 1024)
                read_Servo4_p = 1024;
      if (read_Servo4_p < 0)
                read_Servo4_p = 0;
      read_Servo4_p = map(read_Servo4_p, 0, 1024, 1222, 1722);
      Serial.print("read_Servo_p:");
      Serial.print(read_Servo0_p);
      Serial.print(":");
      Serial.print(read_Servo1_p);
      Serial.print(":");
      Serial.print(read_Servo2_p);
      Serial.print(":");
      Serial.print(read_Servo3_p);
      Serial.print(":");
      Serial.print(read_Servo4_p);
      Serial.print("");
      if (abs(read_Servo0_p - read_Servo0) > 20) {
                //Serial.print(read_Servo0_p - read_Servo0);
                Serial.println("!0");
                return false;
      else if (abs(read_Servo1_p - read_Servo1_p) > 20) {
                Serial.println("!1");
                return false;
      else if (abs(read_Servo2_p - read_Servo2_p) > 20) {
                Serial.println("!2");
                return false;
      else if (abs(read_Servo3_p - read_Servo3_p) > 20) {
                Serial.println("!3");
                return false;
      else if (abs(read_Servo4_p - read_Servo4_p) > 20) {
                Serial.println("!4");
                return false;
      else if (abs(EEPROM.read(addr - 5) - read_Servo0) > 20) {
                /*Serial.print(":");
                Serial.print(EEPROM.read(addr - 5) - read_Servo0);
                Serial.print("");*/
                Serial.println("!5");
                return false;
      else if (abs(EEPROM.read(addr - 4) - read_Servo1) > 20) {
                Serial.println("!6");
                return false;
      else if (abs(EEPROM.read(addr - 3) - read_Servo2) > 20) {
                Serial.println("!7");
                return false;
      else if (abs(EEPROM.read(addr - 2) - read_Servo3) > 20) {
                Serial.println("!8");
                return false;
      else if (abs(EEPROM.read(addr - 1) - read_Servo4) > 20) {
                Serial.println("!9");
                return false;
      else
                return true;
void get_Servo()
      read_Servo0 = analogRead(A0);
      if (read_Servo0 > max_0)
                read_Servo0 = max_0;
      if (read_Servo0 < min_0)
                read_Servo0 = min_0;
      read_Servo0 = map(read_Servo0, min_0, max_0, 611, 2389);
      read_Servo1 = analogRead(A1);
      if (read_Servo1 > max_1)
                read_Servo1 = max_1;
      if (read_Servo1 < min_1)
                read_Servo1 = min_1;
      read_Servo1 = map(read_Servo1, min_1, max_1, 611, 2389);
      read_Servo2 = analogRead(A2);
      if (read_Servo2 > max_2)
                read_Servo2 = max_2;
      if (read_Servo2 < min_2)
                read_Servo2 = min_2;
      read_Servo2 = map(read_Servo2, min_2, max_2, 611, 2389);
      read_Servo3 = analogRead(A3);
      if (read_Servo3 > max_3)
                read_Servo3 = max_3;
      if (read_Servo3 < min_3)
                read_Servo3 = min_3;
      read_Servo3 = map(read_Servo3, min_3, max_3, 611, 2389);
      read_Servo4 = analogRead(A4);
      if (read_Servo4 > 1024)
                read_Servo4 = 1024;
      if (read_Servo4 < 0)
                read_Servo4 = 0;
      read_Servo4 = map(read_Servo4, 0, 1024, 1222, 1722);
      EEPROM.write(addr, read_Servo0);
      delay(100);
      addr++;
      EEPROM.write(addr, read_Servo1);
      delay(100);
      addr++;
      EEPROM.write(addr, read_Servo2);
      delay(100);
      addr++;
      EEPROM.write(addr, read_Servo3);
      delay(100);
      addr++;
      EEPROM.write(addr, read_Servo4);
      delay(100);
      addr++;
      Serial.print("read_Servo:");
      Serial.print(read_Servo0);
      Serial.print(":");
      Serial.print(read_Servo1);
      Serial.print(":");
      Serial.print(read_Servo2);
      Serial.print(":");
      Serial.print(read_Servo3);
      Serial.print(":");
      Serial.print(read_Servo4);
      Serial.print("");
void write_eeprom_end()
      EEPROM.write(addr, 6666);
      delay(100);
void read_eeprom()
      for (int i = 0; i < 512; i)
                int value = EEPROM.read(i);
                delay(100);
                Serial.print(value);
                if ((i+1) % 5 == 0)
                        Serial.print("");
                else
                        Serial.print(":");
                if (value != 6666)
                        i++;
                else
                        i = 512;
      Serial.print("");
void get_Servo4()
      pos = analogRead(A4);
      myservo4.writeMicroseconds(map(pos, 0, 1024, 1222, 1722));
void servo_detach()
      myservo0.detach();
      myservo1.detach();
      myservo2.detach();
      myservo3.detach();
      //myservo4.detach();
void servo_attach()
      myservo0.attach(8);
      myservo1.attach(9);
      myservo2.attach(10);
      myservo3.attach(11);
      //myservo4.attach(12);
void bottom_press()
      long now_time = millis();
      //detachInterrupt(digitalPinToInterrupt(UPS_INT_PIN));
      detachInterrupt(7);
      delay(5);
      if (digitalRead(7) == LOW)
                bottom = !bottom;
                Serial.println(bottom);
                unsigned long value;
                while (digitalRead(7) == LOW);
                if (millis() - now_time >= 1000)
                        bottom_pressed = !bottom_pressed;
                        Serial.println("LONG PRESS!");
                        digitalWrite(B_PIN, LOW);
                        delay(500);
                        digitalWrite(B_PIN, HIGH);
                        delay(500);
                        delay(500);
                        delay(500);
                        if (bottom_pressed)
                              write_eeprom_end();
                              read_eeprom();
                              addr = 0;
                              servo_attach();
                        /*else
                              digitalWrite(G_PIN, LOW);
                              delay(500);
                              digitalWrite(G_PIN, HIGH);
                              delay(500);
                              delay(500);
                              delay(500);
                        //read_eeprom();
                        //addr = 0;
                else
                        get_Servo();
                        while (!match_servo())
                              addr -= 5;
                              get_Servo();
                        Serial.println("EEPROM WRITE END");
                        Serial.print(EEPROM.read(addr - 5));
                        Serial.print(":");
                        Serial.print(EEPROM.read(addr - 4));
                        Serial.print(":");
                        Serial.print(EEPROM.read(addr - 3));
                        Serial.print(":");
                        Serial.print(EEPROM.read(addr - 2));
                        Serial.print(":");
                        Serial.println(EEPROM.read(addr - 1));
                        digitalWrite(R_PIN, LOW);
                        delay(500);
                        digitalWrite(R_PIN, HIGH);
                        delay(500);
                        delay(500);
                        delay(500);
      attachInterrupt(7, bottom_press, FALLING);
void get_analog()
      for (pos = 10; pos <= 170; pos += 10) // goes from 0 degrees to 180 degrees
      {                                  // in steps of 1 degree
                myservo0.write(pos);
                myservo1.write(pos);
                myservo2.write(pos);
                myservo3.write(pos);
                myservo4.write(map(pos, 10, 170, 65*11, 110*11));// tell servo to go to position in variable 'pos'
                delay(500);                     // waits 15ms for the servo to reach the position
                if (pos == 10 || pos == 170)
                        Serial.print(analogRead(A0));
                        Serial.print(" : ");
                        Serial.print(analogRead(A1));
                        Serial.print(analogRead(A2));
                        Serial.print(analogRead(A3));
                        Serial.print("");
      for (pos = 170; pos >= 10; pos -= 10)   // goes from 180 degrees to 0 degrees
                //if(pos >= 65 && pos <= 110)
                        Serial.print("");
void process_servo()
      int servo_pos_0, servo_pos_1, servo_pos_2, servo_pos_3, servo_pos_4;
      int servo_des_0, servo_des_1, servo_des_2, servo_des_3, servo_des_4;
      int servo_move_0, servo_move_1, servo_move_2, servo_move_3, servo_move_4;
      int rate_0, rate_1, rate_2, rate_3, rate_4, servo_move_max, rate_time;
      servo_pos_0 = read_Servo0;
      servo_pos_1 = read_Servo1;
      servo_pos_2 = read_Servo2;
      servo_pos_3 = read_Servo3;
      servo_pos_4 = read_Servo4;
      myservo0.writeMicroseconds(servo_pos_0);
      myservo1.writeMicroseconds(servo_pos_1);
      myservo2.writeMicroseconds(servo_pos_2);
      myservo3.writeMicroseconds(servo_pos_3);
      myservo4.writeMicroseconds(servo_pos_4);
      servo_des_0 = EEPROM.read(addr);
      //delay(100);
      addr++;
      servo_des_1 = EEPROM.read(addr);
      //delay(100);
      addr++;
      servo_des_2 = EEPROM.read(addr);
      //delay(100);
      addr++;
      servo_des_3 = EEPROM.read(addr);
      //delay(100);
      addr++;
      servo_des_4 = EEPROM.read(addr);
      //delay(100);
      addr++;
      servo_move_0 = servo_des_0 - servo_pos_0;
      servo_move_1 = servo_des_1 - servo_pos_1;
      servo_move_2 = servo_des_2 - servo_pos_2;
      servo_move_3 = servo_des_3 - servo_pos_3;
      servo_move_4 = servo_des_4 - servo_pos_4;
      servo_move_max = max(abs(servo_move_0), max(abs(servo_move_1), max(abs(servo_move_2), max(abs(servo_move_3), abs(servo_move_4)))));
      rate_0 = servo_move_0 * 50 / servo_move_max;
      rate_1 = servo_move_1 * 50 / servo_move_max;
      rate_2 = servo_move_2 * 50 / servo_move_max;
      rate_3 = servo_move_3 * 50 / servo_move_max;
      rate_4 = servo_move_4 * 50 / servo_move_max;
      /*Serial.print("Servo_rate:");
      Serial.print(rate_0);
      Serial.print(rate_1);
      Serial.print(rate_2);
      Serial.print(rate_3);
      Serial.print(rate_4);
      Serial.print("");*/
      rate_time = servo_move_max;
      //rate_num = 5;
      //int rate_num = 0;
      while (rate_time)
                if (rate_time < 50)
                        servo_pos_0 = servo_des_0;
                        servo_pos_1 = servo_des_1;
                        servo_pos_2 = servo_des_2;
                        servo_pos_3 = servo_des_3;
                        servo_pos_4 = servo_des_4;
                        rate_time = 0;
                else
                        servo_pos_0 += rate_0;
                        servo_pos_1 += rate_1;
                        servo_pos_2 += rate_2;
                        servo_pos_3 += rate_3;
                        servo_pos_4 += rate_4;
                        rate_time -= 50;
                //rate_num++;
                /*Serial.print("rate_time:");
                Serial.print(rate_time);
                Serial.print("Servo_test:");
                Serial.print(servo_pos_0);
                Serial.print(servo_pos_1);
                Serial.print(servo_pos_2);
                Serial.print(servo_pos_3);
                Serial.print(servo_pos_4);
                Serial.print(rate_num);
                Serial.print("");*/
                myservo0.write(servo_pos_0);
                myservo1.write(servo_pos_1);
                myservo2.write(servo_pos_2);
                myservo3.write(servo_pos_3);
                myservo4.write(servo_pos_4);
                delay(40);
      /*Serial.print(servo_pos_0);
      Serial.print("");*/
      read_Servo0 = servo_des_0;
      read_Servo1 = servo_des_1;
      read_Servo2 = servo_des_2;
      read_Servo3 = servo_des_3;
      read_Servo4 = servo_des_4;
void config_init()
      min_0 = 177;
      min_1 = 178;
      min_2 = 194;
      min_3 = 172;
      max_0 = 660;
      max_1 = 668;
      max_2 = 704;
      max_3 = 650;
      pinMode(A0, INPUT);
      pinMode(A1, INPUT);
      pinMode(A2, INPUT);
      pinMode(A3, INPUT);
      pinMode(A4, INPUT);
      pinMode(7, INPUT_PULLUP);
      pinMode(R_PIN, OUTPUT);
      pinMode(G_PIN, OUTPUT);
      pinMode(B_PIN, OUTPUT);
      myservo0.attach(8);
      myservo1.attach(9);
void setup()
      config_init();
      Serial.begin(9600);
void loop()
      if (bottom_pressed)
                if (eeprom_end())
                        process_servo();
                else
                        addr = 0;
      else
                servo_detach();
                get_Servo4();
                delay(50);
//for(pos = 10; pos <= 170; pos += 1) // goes from 0 degrees to 180 degrees
//{                                  // in steps of 1 degree
//myservo0.write(90);
//myservo1.write(90);
//myservo2.write(90);
//myservo3.write(90);
////if(pos >= 65 && pos <= 110)
//myservo4.write(map(pos,10,170,65,110));// tell servo to go to position in variable 'pos'
//delay(20);                     // waits 15ms for the servo to reach the position
//for(pos = 170; pos>=10; pos -= 1)   // goes from 180 degrees to 0 degrees
//}de
原帖出处:http://www.arduino.cn/thread-23525-1-1.html
zjs123 发表于 2017-2-10 11:22:40
顶贴是一种美德!
川师鲤鱼 发表于 2017-2-10 13:52:12
不错不错
昶平 发表于 2017-2-10 21:34:16
顶一个。。。
suin 发表于 2017-2-11 19:24:00
不错,收藏了,有时间搞个玩玩
悠牧人 发表于 2017-2-13 18:31:35
帮顶一个
tjcdq 发表于 2017-2-15 00:09:29
很完整的资料,收藏了。多谢!
madbeef 发表于 2017-2-15 17:15:51
结合人工智能的话,厉害了
查看完整版本: 基于intel Curie的开源机械臂(转帖)
