转国外帖子 后续不断更新!
本帖最后由 24k纯帅 于 2014-7-25 19:56 编辑Long, smooth and gentle flights are the standards for this plane.
Topmodel uses construction techniques like CNC milling and laser cutting to build this plane. The wings and tail are all balsa with a carbon fiber main spar and leading edge. The gel coated fuselage has a carbon fiber tapered tail boom. The model is covered with Ultracote. This sailplane only needs basic assembly and motor/radio installation. The two piece wing is removable.
Special Features:
- Ailerons, Flaps and V-tail
- Covering, with all seams hand-sealed
- Gel-coated fiberglass fuselage with carbon fiber boom
- Two-piece wing with ailerons and oversized flaps
- Ready-built Balsa/Carbon Fiber 2-piece wing design
- Ultracote covered wings and tail parts
- All necessary hardware
Click here for more information on this plane.
Discussion
长,光滑柔和的航班是这架飞机的标准。
Topmodel使用施工技术数控铣和激光切割建造这架飞机。翅膀和尾巴都是轻的碳纤维主要spar和前沿。机身凝胶涂层的碳纤维锥形尾巴繁荣。模型是Ultracote覆盖着。这滑翔机只需要基本的装配和运动/无线电安装。两件翼是可拆卸的。
特殊功能:
——副翼、襟翼和V-tail
——Coverin
你自己翻译的? 情为何物 发表于 2014-7-25 15:59 static/image/common/back.gif
你自己翻译的?
不会 我英语只几十分 电脑在线翻译http://www.moz8.com/mobcent/app/web/../../app/data/phiz/default/04.png
来自安卓客户端 后续跟帖!
Infinity Hobby Folding Prop Blades For The DJI S800 - S1000
For anyone using the DJI style 15" folding props, there is a new affordable option available!News By Stephen Cinch | Jul 23, 2014, 10:03 AM
http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai16954497-115-thumb-prop%20splash.jpgAn affordable 15" DJI style folding prop option!
For the many DJI S800 and S1000 owners and the countless others who have adopted the DJI style folding propellers there was only a few options available and most tended to be quite expensive. Infinity hobby has released a new DJI style folding prop that is more efficient and cheaper! They are only $9.99 US for a four pack of CW or CCW blades!Description: The advanced propeller is designed based on DJI EVO foldable propellers but have a different shape and are proven to be more efficient.
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai16954488-24-thumb-3.jpg?d=1406125983Top DJI, bottom Infinity Hobby
Manufactured by "Made-In-Taiwan" precise molds. Each propeller is made with precise accuracy doesn’t need any additional balancing.
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai16954487-162-thumb-2.jpg?d=14061259832 Blade - balanced perfectly!
These propellers have a conical propeller assembly hole. It is designed to make sure there is a tight connection between the brass bushing and propeller. This in turn decreased the operation vibration of the propeller.
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai16954492-190-thumb-7.jpg?d=1406125983Conical prop bushing
Install direction of brass bush (0 min 26 sec)
Pics and video of the efficiency!
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954486-88-thumb-1.jpg?d=14061259833 Blade
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954487-162-thumb-2.jpg?d=14061259832 Blade - balanced perfectly!
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954488-24-thumb-3.jpg?d=1406125983Top DJI, bottom Infinity Hobby
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954489-122-thumb-4.jpg?d=1406125983Pack of 4 CW or CCW is $9.99!!
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954490-81-thumb-5.jpg?d=1406125983Prop Blade Dimensions
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954491-50-thumb-6.jpg?d=1406125983Left infinity Hobby, right DJI
Foldable Prop For Multi-copter (1 min 8 sec)
Also available from Infinity Hobby are the adaptors needed to use folding props on any 12mm 2 hole mount motor. (That will accept a 15" prop load)
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954494-0-thumb-9.jpg?d=14061259902 blade adaptor
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954493-116-thumb-8.jpg?d=14061259832 blade adaptor measurements
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954495-224-thumb-10.jpg?d=14061259903 blade adaptor
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26954496-89-thumb-11.jpg?d=14061259903 blade adaptor measurements
For more information on the blades go HEREFor more information on the prop adaptors go HERELast edited by Sleepyc; Jul 23, 2014 at 09:47 AM..
翻译
无限爱好折叠收S800——S1000支撑叶片
对于任何使用收风格15“折叠道具,有一个新的负担得起的选择!
新闻
2014年由Stephen有把握| 7月23日,每次
一个负担得起的15个“收风格折叠道具的选择!
许多收S800和S1000所有者和无数人采用了折叠收风格螺旋桨只有几个选择,大多数往往是非常昂贵的。无限爱好已经发布了一个新的收风格折叠支撑更有效和更便宜的!他们只是9.99美元我们四个包的连续波或公约刀片!
描述:先进的螺旋桨设计基于收EVO可折叠的螺旋桨,但有不同的形状
由“Made-In-Taiwan精密模具制造。每个螺旋桨用精确的精度不需要任何额外的平衡。
叶片2 -平衡的完美!
这些螺旋桨锥形推进器装配孔。它的目的是确保有一个紧密的黄铜衬套和螺旋桨之间的连接。这反过来又降低了操作的螺旋桨振动。
图片和视频的效率!
也可以从无限爱好适配器需要使用折叠道具在任何12毫米2洞山电动机。(能接受15”支撑负载)
叶片上的更多信息请到这里
支持适配器上的更多信息请到这里
最后编辑Sleepyc;2014年7月23日09:47点. .
微野兽加上&高清下一个级别。新闻通过尼尔·戴维斯|2014年7月7日08:48
http://static.rcgroups.net/forums/attachments/3/3/9/2/0/6/ai16909848-6-thumb-main1.jpg高技术简单
如果你知道RC直升机陀螺仪,那么你可能听说过的野兽X FBL系统。的家伙在MicroBeast又一对新的IRCHA FBL系统及时。高清(重型)可以处理当前的最标准的伺服系统,和2细胞系统。在有限的信息加上,高清,这些看起来保持3 d FBL系统的速度。
[*]http://static.rcgroups.net/forums/attachments/3/3/9/2/0/6/ai16909851-75-thumb-microbeast_plus_sideview.jpg?d=1404678981比较
特性
[*]工作电压3.5 V - 8.5 V直流(操作2-cell脂肪)
[*]32位处理器的手臂
[*]六轴MEMS传感器(陀螺仪+加速度计)
[*]尺寸36 x 25 x 21毫米36 x 25 x 14毫米
[*]重量(没有电缆)大约19 g
有关更多信息,请到这里。最后由ndfly700编辑;2014年7月6日 03:46点..讨论
出现在http://static.rcgroups.net/forums/images/articles/logo-ezone.png
本文讨论打印版本所有由该作者的文章
社会统计数据观点:878
分享
推特
http://static.rcgroups.net/forums/images/beta/buttons3/reply.gif
线程工具 http://static.rcgroups.net/forums/images/beta/misc/menu_open.gif?v=1
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月7日04:20点
[*]# 2
imacav8r
注册用户
美国,TX,休斯顿
2004年7月加入
261个帖子
想知道这些是什么时候是可用的。
没有人知道,Microbeast不会回答这个问题。http://static.rcgroups.com/forums/images/smilies/mad.gif
http://static.rcgroups.net/forums/images/beta/statusicon/icon-status-offline.pnghttp://static.rcgroups.net/forums/images/beta/buttons3/icon-search.png
http://static.rcgroups.net/forums/images/beta/buttons3/quote.gif
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月9日01:22点
[*]# 3
鲁迪·阿克曼
注册用户
美国休斯顿,德克萨斯州
2000年11月加入
476个帖子
这里什么改善?
只是,他们可以处理2 s脂肪的?
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月12日,51分
[*]# 4
Pawndmonium
注册用户
美国,CA,惠蒂尔
2013年12月加入
6帖子
改进后可以找到上面的链接。大的更新MEMS陀螺仪,不太敏感的振动以及加速度计更新六轴。
凤凰城的航班外面还装有齿轮三+ CarbonCase英雄添加一个小珠宝,并且保护你的高清摄像头。新闻通过马特|2014年7月17日09:06
http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai16938566-242-thumb-goprocase_splash.jpg31克。外面还装有完整功能。外面还装有的英雄三+ CarbonCase从凤凰城飞行装置是一个时髦的除了你的废票multirotor或固定翼废票平台。重仅31克,有一个滑动阅读外面还装有门毫不费力地插入你的相机。外面还装有旨在保留所有功能访问漏洞的力量和记录按钮,领导,和USB接口。钩和环槽后推拉门提供额外的安装选项。一个镜头盖还包括保持玻璃划痕是免费的,直到飞行时间。
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26938599-79-thumb-goprocase1.jpg?d=1405604997凤凰飞外面还装有齿轮CarbonCase重31克
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26938598-48-thumb-goprocase2.jpg?d=1405604997读的门在CarbonCase插槽钩和环肩带
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26938597-139-thumb-goprocase3.jpg?d=1405604997
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26938596-106-thumb-goprocase4.jpg?d=1405604997镜头盖是包含在凤凰城外面还装有齿轮CarbonCase航班
点击这里阅读更多关于外面还装有的CarbonCase最后由马特·甘恩编辑;2014年7月17日 08:52我..讨论
Lazer230废票四被称为一个“干净和脏”系统,230年雷泽隔离时间视频相机。新闻通过马特|2014年7月9日,上午11:53
http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai16917072-227-thumb-lazer_splash.jpg综合230毫米工具包Hobbyking.com刚刚介绍了另一个小四平台称为Lazer230;这一次,一个名为“干净和脏”的新球场。系统使用振动阻尼器来隔离发动机和飞行控制器和摄像头支持氛围。Clean-and-Dirty系统允许您运行更严格的私家侦探D年代,果冻杯免费视频。由G10复合,雷泽230是230毫米长,建议5”道具、2 - 3细胞脂肪范围800 - 1300 mah,和1506 - 2208大小的无刷电机。设置它有别于无数其他四��胎在这个类中,雷泽红色阳极电镀铝的僵局。的Lazer230废票四目前可以通过Hobbyking为22.99美元。
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26917080-198-thumb-lazer1.jpg?d=1404910823Lazer230废票四
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26917079-79-thumb-Lazer2.jpg?d=1404910823
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26917078-142-thumb-lazer3.jpg?d=1404910823G10 Lazer230建设
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26917077-107-thumb-lazer4.jpg?d=1404910823一个包括废票相机挂载
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26917076-201-thumb-lazer5.jpg?d=1404910823vibration-isolators Lazer230特性
[*]http://static.rcgroups.net/forums/attachments/2/7/4/2/9/6/ai26917075-171-thumb-lazer6.jpg?d=1404910823Lazer230工具包
特点:
[*]复合结构
[*]广泛的电机和电源选项
[*]大二次隔振框架更多的空间和布局
[*]紧凑的尺寸接近乱飞的障碍
规格:
[*]轴距:230毫米
[*]重量:180克
[*]身高:82毫米与起落架和中心笼子
要求:
[*]4 x汽车1506 ~ 2208
[*]1 x电池800 ~ 1300 mah 7.4 ~ 11.1 v(2或3细胞脂肪)
[*]4 x螺旋桨5
[*]4倍ESC年代7 ~ 12
[*]1 x弹性飞行控制器
[*]4 ch电台(6 ch适合废票和FC使用)
[*]废票装置(可选)
点击这里阅读更多关于Lazer230最后由马特·甘恩;编辑(2014年7月9日 08:02我..
Xaircraft美国分配10”和7”5.8 GHZ多样性自我驱动的废票显示器!嘿伙计们,厌倦了试图把所有的电线在你的废票显示器看起来干净和插入吗?Xaircraft美国进口了一些10”和7”5.8 GHZ多样性监测,自我驱动和摇滚!新闻通过Stephen有把握的事情|2014年6月28日,08:39
http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai16877641-127-thumb-monitor%20splash.jpgXaircraft美国进口一些废票监控,保持你的设置非常清晰,非常容易设置和工作真的很好!
携带我的废票装备很多拍摄后,我意识到我需要更好的东西。我的显示器固定到一个三角架,大3 s电池连接到电缆进了监视器,分裂然后驱动我的视频接收机。我有接收器安装一块玻璃纤维的螺纹的监控。Velcrow无处不在,整个事情看起来不专业无论多少我清理组装。当我添加了一个专用的相机op操作一年前,乱翻了一倍。老实说我需要找到更好的工作。我说我的朋友从Xaircraft美国,除了处理Xaircraft行产品进口和销售其他几个行齿轮包括废票系统。我告诉他我正在寻找一个更好的监控系统,和他说,他在一些10”和7”显示器,内置电源、内置的多样性5.8 GHZ接收器,超级干净。我立即跃升至关注和告诉他我把大小。7“我的收音机和10”我的摄影师。监视器几天到达,盒装好,如此简单的设置我很尴尬我之前没有发现过了。7“监控”频道搜索”功能,它会发现积极的信号传输和锁。10“有一个简单的跳线开关设置,你选择你的发射机频率发送和简单地将指拨开关设置为适当的设置。我监控到信号锁定在两个ImmersionRC 600 w TX发送。连续监测的标准基本的天线,但把你最喜欢的蓝色光束或贴片天线是一个微风。我容易得到1000英尺+范围几乎没有屏幕的杂音或模糊性在两个显示器。7”有内部电池,充电,通过将包括充电电缆。据说去年5个小时。我还没有达到这个限制,但监控从来没有死在我在一天的拍摄。(白天打开和关闭)10”有几个不同的电池安装允许您使用几个“佳能”式相机电池。监视器附带1电池和一个充电器,但额外的电池可以在Ebay上找到超级便宜,你就会有足够的力量持续好几天!少,减少电缆障碍和轻松移动的能力,新的显示器在我眼里已经成为必须。他们看起来专业,包很容易和伟大的工作。你还能要求什么?7“5.8 ghz自我驱动的多样性监测售价:199美元
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877589-143-thumb-IMG_2361.jpg?d=14036304527“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877590-230-thumb-IMG_2362.jpg?d=14036304527“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877591-201-thumb-IMG_2363.jpg?d=14036304527“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877592-166-thumb-IMG_2364.jpg?d=14036304527“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877594-136-thumb-IMG_2365.jpg?d=14036304527“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877595-113-thumb-IMG_2366.jpg?d=14036304527“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877596-74-thumb-IMG_2367.jpg?d=14036304527“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877597-50-thumb-IMG_2368.jpg?d=14036304527“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877633-4-thumb-IMG_2386.jpg?d=14036306457“5.8 GHZ多样性自我驱动的废票监测准备工作!
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877635-205-thumb-IMG_2388.jpg?d=14036306457“5.8 GHZ多样性自我驱动的废票监控视图大小。
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877640-185-thumb-IMG_2454.jpg?d=14036306877“5.8 GHZ多样性自我驱动与AD1废票监控工作
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877636-151-thumb-IMG_2392.jpg?d=14036306457“5.8 GHZ多样性自我驱动与HighOne废票监控工作!
10“5.8 ghz自我驱动的多样性监测售价:249美元
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877620-113-thumb-IMG_2374.jpg?d=140363055110“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877621-249-thumb-IMG_2375.jpg?d=140363055110“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877622-178-thumb-IMG_2376.jpg?d=140363055110“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877623-59-thumb-IMG_2377.jpg?d=140363055110“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877624-220-thumb-IMG_2378.jpg?d=140363055110“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877625-86-thumb-IMG_2379.jpg?d=140363055110“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877626-73-thumb-IMG_2380.jpg?d=140363055110“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877627-170-thumb-IMG_2381.jpg?d=140363055110“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877630-225-thumb-IMG_2383.jpg?d=140363064510“5.8 GHZ多样性自我驱动的废票监视器
[*]http://static.rcgroups.net/forums/attachments/1/0/9/5/4/4/ai26877637-248-thumb-IMG_2393.jpg?d=140363064510“5.8 GHZ多样性自我驱动的废票监测准备工作(我更喜欢它在三脚架上)
推特
第1页的21
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月28日,04:36点
[*]# 2
rclab1
美国:纽约LakeGeorge
美国
2010年5月加入
4393个帖子
所有监视我用(我买了他们全部)
检查我的博客DIY护目镜。
这两个显示器屏幕是最好的废票特定监视我
曾经买了!5”和8”
http://www.getfpv.com/5-lumenier-lcd-fpv-monitor.html
http://www.readymaderc.com/store/ind...oducts_id=1529
http://www.getfpv.com/8-lumenier-lcd-fpv-monitor.html
http://www.readymaderc.com/store/ind...oducts_id=1191
现在与多样性或VideoRX建成的
http://www.foxtechfpv.com/32ch - 58 - g - d...or - p - 1493. - html
http://www.getfpv.com/8-lumenier-lcd...-receiver.html
http://www.foxtechfpv.com/foxtech - pv...tx - p - 1387. - html
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月28日,04:38点
[*]# 3
rclab1
美国:纽约LakeGeorge
美国
2010年5月加入
4393个帖子
10“监控你在审核发布
不够亮。大量的废票代
并返回抱怨10”。
总的来说,最亮/和清晰的(美国东部时间)是8”。
5”一样清晰,只是规模较小。
我在DIY镜使用,没有框架
使它更轻。
注:
这些价格你列出过高!
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月28日05:20点
[*]# 4
SleepyC
MultiRotard
http://static.rcgroups.net/forums/customavatars/avatar109544_6.gif
美国,哦,极光
2006年8月加入
975个帖子
我的10”很好。我的凸轮op不断使用它从来没有一个问题或抱怨。
明亮的阳光下。
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月28日,05:32点
[*]# 5
rclab1
美国:纽约LakeGeorge
美国
2010年5月加入
4393个帖子
报价:
最初由Sleepyc发布http://static.rcgroups.net/forums/images/beta/buttons3/viewpost.gif
明亮的阳光下。
只是给你一些信息如果你曾经想要的
从你的十大“监控升级。如果你满意它,
所以无论是.....只是通知你:-)
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月29日,于点
[*]# 6
mcrown
马丁
小君2014年加入
11日文章
这类废票显示器似乎要么32 ch(或更少)5.8 Ghz RX + DVR但没有内置电池,或32 ch(或更少)5.8 Ghz RX +内部电池但没有DVR。
有32个ch 5.8 GHz RX(多样性或单一RX)+内部电池+ DVR将是一个即时的废票成功!我搜索互联网数日,但找不到这种组合。任何人吗?
我使用RC800(32 ch 5.8 GHz单一RX + DVR)小(1100 maH 3 s -好一个小时废票)脂肪用尼龙搭扣固定背面。
最后由mcrown编辑;2014年6月29日 03:50点.
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月29日,03:38点
[*]# 7
rclab1
美国:纽约LakeGeorge
美国
2010年5月加入
4393个帖子
得到8”。
最聪明,最清晰的视频监视器
注:
我希望这些供应商实际阅读
论坛的显示器或一个简单的点狂热用户
会对他们产生销售.....
2014年6月30日,03:50点
# 8
homeslice976
注册用户
2014年2月加入
69个帖子
报价:
最初由mcrown发布
我没有经验与这些所以我不能评论的质量。
7“5.8 g 32 ch DVR内部可容纳2 s
7“5.8 g 32 ch DVR与内部电池(显然这没有附带一个充电适配器(http://www.banggood.com/boscam - rx - lc... - p - 917321. - html)
2014年7月1日,03:17点
# 9
SleepyC
MultiRotard
美国,哦,极光
2006年8月加入
975个帖子
报价:
最初由rclab1发布
得到8”。
最聪明,最清晰的视频监视器
注:
我希望这些供应商实际阅读
论坛的显示器或一个简单的点狂热用户
会对他们产生销售.....
我喜欢8“很多!
2014年7月1日,03:38点
# 10
rclab1
美国:纽约LakeGeorge
美国
2010年5月加入
4393个帖子
是的8”监视器是最好的了。
有三个相同的版本。
(没有VidRx,1 VidRx和多样性版)
所有这些8”显示器是相同的的! ! ! !
效果最好的w / Boscams VidTx。
(FatShark / ImmersionRC VidTx有同步问题,
近距离的工作,但不知道会发生什么500英尺之外)
把你的选择!和它不是199美元
XAirCarft会出售很多这些只有他们使用正确的监控
(j / k,出售你想要的,它不是我的公司)
http://www.troybuiltmodels.com/items...19 - 58 g - 32. - html
http://hobbywireless.com/portable - vi...in - p - 1270. - html
感觉世界7和8“废票液晶显示器w /内置的5.8 ghz视频接收器——收兼容!(2分33秒)
最后由rclab1编辑;2014年7月1日 04:10点.
2014年7月2日,03:57点
# 11
mcrown
马丁
小君2014年加入
11日文章
@homeslice976:
- >谢谢你指出这一个!事实上这Skyzone RC 700 d - 700 d或天空这一切:32 ch 5.8 GHz多样性RX +内部电池+ DVR。似乎2014年4月底以来,对我来说太迟了因为我已经买了RC800早两个月。
7“5.8 g 32 ch DVR与内部电池(显然这没有附带一个充电适配器(http://www.banggood.com/boscam - rx - lc... - p - 917321. - html))- - - >这个RX-LCD5802没有DVR功能……
最后由mcrown编辑;2014年7月2日 有机会点.
2014年7月2日,04:40点
# 12
homeslice976
注册用户
2014年2月加入
69个帖子
啊你是对的。我本可以发誓我看见,在描述. .我的眼睛一定是玩把戏
2014年7月2日11:41点
# 13
Witoldc
注册用户
2014年2月加入
168个帖子
8“Lumenier看起来不错。谁知道如何比较黑珍珠,似乎所有的愤怒这些天吗?
另外,似乎为我们供应商缺货……
2014年7月3日,09:57
# 14
SleepyC
MultiRotard
美国,哦,极光
2006年8月加入
975个帖子
我不知道黑珍珠,但这8英寸在3天很好的陪伴我在刚刚过去的这个周末8小时在炎热的太阳,我能够看到一切我需要无论在阳光下我在哪里。
我真的很喜欢8”和我的凸轮op很满意10”固定到一个三角架。
2014年7月3日,02:12点
# 15
davidsz
注册用户
2013年7月加入
272个帖子
报价:
最初由homeslice976发布
我没有经验与这些所以我不能评论的质量。
这7英寸废票监控HD 1024 * 1024,5.8 g 32 ch双重接收机模型,500 cd高亮度,雪屏幕,内置的DVR和电池,HDMI输入
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月30日,03:50点
[*]# 8
homeslice976
注册用户
2014年2月加入
69个帖子
报价:
最初由mcrown发布http://static.rcgroups.net/forums/images/beta/buttons3/viewpost.gif
我没有经验与这些所以我不能评论的质量。
http://static.rcgroups.net/forums/images/beta/statusicon/icon-status-online.pnghttp://static.rcgroups.net/forums/images/beta/buttons3/icon-search.png
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月1日,03:17点
[*]# 9
SleepyC
MultiRotard
美国,哦,极光
2006年8月加入
975个帖子
报价:
最初由rclab1发布http://static.rcgroups.net/forums/images/beta/buttons3/viewpost.gif
得到8”。
最聪明,最清晰的视频监视器
注:
我希望这些供应商实际阅读
论坛的显示器或一个简单的点狂热用户
会对他们产生销售.....
我喜欢8“很多!
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月1日,03:38点
[*]# 10
rclab1
美国:纽约LakeGeorge
美国
2010年5月加入
4393个帖子
是的8”监视器是最好的了。
有三个相同的版本。
把你的选择!和它不是199美元http://static.rcgroups.com/forums/images/smilies/rolleyes.gif
XAirCarft会出售很多这些只有他们使用正确的监控http://static.rcgroups.com/forums/images/smilies/biggrin.gif
(j / k,出售你想要的,它不是我的公司http://static.rcgroups.com/forums/images/smilies/biggrin.gif)
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月2日,03:57点
[*]# 11
mcrown
马丁
小君2014年加入
11日文章
@homeslice976:
- >谢谢你指出这一个!事实上这Skyzone RC 700 d - 700 d或天空这一切:32 ch 5.8 GHz多样性RX +内部电池+ DVR。似乎2014年4月底以来,对我来说太迟了http://static.rcgroups.com/forums/images/smilies/frown.gif因为我已经买了RC800早两个月。
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月2日,04:40点
[*]# 12
homeslice976
注册用户
2014年2月加入
69个帖子
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月2日11:41点
[*]# 13
Witoldc
注册用户
2014年2月加入
168个帖子
另外,似乎为我们供应商缺货……
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月3日,09:57
[*]# 14
SleepyC
MultiRotard
美国,哦,极光
2006年8月加入
975个帖子
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年7月3日,02:12点
[*]# 15
davidsz
注册用户
2013年7月加入
272个帖子
报价:
最初由homeslice976发布http://static.rcgroups.net/forums/images/beta/buttons3/viewpost.gif
我没有经验与这些所以我不能评论的质量。
FPVRaptor V2升级目的废票平台建立新闻通过杰森•科尔|2014年6月23日,47
http://static.rcgroups.net/forums/attachments/2/2/5/6/4/ai16874221-84-thumb-main.jpg高度耐用,设计时考虑到废票
从Volantex RC FPVRaptor V2是2米(78.7”)的翼展推杆式飞机是为废票的人量身定做的。它有一个塑料一体式机身,超耐用,不允许flex的尾部。已经从第一次迭代升级与更高的汽车安装允许10“折叠支撑附加到包含40尺寸直接驱动电动机,由40 ESC操作开关模式BEC。最后组装不需要胶水,机翼和尾部用螺丝连接。尾巴上有一个塑造平台繁荣为附加视频发射器或GPS模块和内部的融合提供了足够的空间来安装你的装置以及一个巨���的飞行电池,10000 mah !查看FPVRaptor Volantex RC。
规格:
[*]翼展:2000毫米(78.7英寸)
[*]总长度:1044毫米(41)
[*]飞行重量:1000克
[*]道具大小:1040折螺旋桨
[*]电机尺寸:4023强大的无刷电机
[*]速度控制:40一个开关BEC无刷ESC转换给这些线圈
[*]伺服系统:包括9-gram伺服* 6个人电脑
[*]建议电池:11.1 v 1800 mah ~ 10000 mah Li-Po
[*]襟翼:是的
[*]大会时间:不到半小时
[*]http://static.rcgroups.net/forums/attachments/2/2/5/6/4/ai16874218-152-thumb-2.png?d=1403534726端配置文件
[*]http://static.rcgroups.net/forums/attachments/2/2/5/6/4/ai26874217-119-thumb-3.png?d=1403534726螺栓上的尾巴
[*]http://static.rcgroups.net/forums/attachments/2/2/5/6/4/ai26874216-86-thumb-4.png?d=1403534726高电机山10”道具
[*]http://static.rcgroups.net/forums/attachments/2/2/5/6/4/ai26874215-52-thumb-5.png?d=1403534726容易获得冠
[*]http://static.rcgroups.net/forums/attachments/2/2/5/6/4/ai26874214-19-thumb-6.png?d=1403534726巨大的2米的翼��
[*]http://static.rcgroups.net/forums/attachments/2/2/5/6/4/ai26874213-243-thumb-7.jpg?d=1403534726GoPro安装区域
[*]http://static.rcgroups.net/forums/attachments/2/2/5/6/4/ai26874212-214-thumb-8.jpg?d=1403534726公开发行提供足够的冷却
讨论
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月24日,04:11有空
[*]# 2
ChrisJ800
塔斯马尼亚电气、直升机、滑翔机
http://static.rcgroups.net/forums/customavatars/avatar12856_3.gif
霍巴特,澳大利亚
2002年10月加入
2515个帖子
我刚我准备少女,更像一天半没有半个小时但花时间交换了一个ESC 5安培BEC我将运行8伺服系统包括锅/倾斜。这里有一个构建线程:http://www.rcgroups.com/forums/showthread.php?t=2149067
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月24日,05:39有空
[*]# 3
cantremember
注册用户
小君2014年加入
87个帖子
这可以在欧洲买吗?不想给我所有的钱定制的许可。
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月24日02:32点
[*]# 4
杰森•科尔
RCG工作人员
http://static.rcgroups.net/forums/customavatars/avatar22564_15.gif
美国、TN、纳什维尔
2003年10月加入
4997个帖子
不确定。您应该能够通过他们的网站和他们联系询问。
http://static.rcgroups.net/forums/images/beta/misc/badge-admin.png
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月24日,02:47点
[*]# 5
Arxangel
注册用户
http://static.rcgroups.net/forums/customavatars/avatar398976_3.gif
保加利亚、Sofia-grad,索非亚
2012年2月加入
1564个帖子
报价:
最初由cantremember发布http://static.rcgroups.net/forums/images/beta/buttons3/viewpost.gif
我将他们的股票,但可能没有提前两个月。现在我的订单正在生产,然后它被加载到一个船,慢慢地走进世界的一部分。http://static.rcgroups.com/forums/images/smilies/smile.gif
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月24日04:04点
[*]# 6
cantremember
注册用户
小君2014年加入
87个帖子
报价:
最初由Arxangel发布http://static.rcgroups.net/forums/images/beta/buttons3/viewpost.gif
我可以住在一起,还有飞来飞去的V1。你乘飞机原始和V2吗?2米的翅膀如何影响飞行吗?飞行时间长,高承载重量吗?
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月24日,04:32点
[*]# 7
Arxangel
注册用户
保加利亚、Sofia-grad,索非亚
2012年2月加入
1564个帖子
报价:
你会发现你正在寻找的答案:所有的http://www.rcgroups.com/forums/showthread.php?t=2149067
在这里:http://www.rcgroups.com/forums/showthread.php?t=2076331
我已经打了很多与V1和V2。遗憾的是,我没有机会测试V2正确,因为它似乎表明,V2翼鼻子不能处理一个非常沉重的飞机很好,所以我设法破产这两套翅膀我之前我可以做一些适当的测试。我重建了但V1 1.6翼,现在它适当的均衡苍蝇很好…但它本质上是一个V1与灰色的机身和V2汽车塔! ! !http://static.rcgroups.com/forums/images/smilies/biggrin.gifhttp://static.rcgroups.com/forums/images/smilies/biggrin.gif
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月26日,十一25点
[*]# 8
Racerx4
注册用户
http://static.rcgroups.net/forums/customavatars/avatar362358_2.gif
美国,TX,车体倒垂
小君2011年加入
108个帖子
我是正确的,现在这架飞机不作为吗?我是寻找飞机的价格甚至volantex其他废票飞机但找不到任何东西。我遗漏了��么东西?
诺亚
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月26日,05:19点
[*]# 9
ChrisJ800
塔斯马尼亚电气、直升机、滑翔机
霍巴特,澳大利亚
2002年10月加入
2515个帖子
你可以在eBay上购买,我看到他们在爱好商店在Oz,我买了http://www.fpvmodel.com/757-v2-fpvra...her-_g611.html
http://static.rcgroups.net/forums/images/beta/statusicon/post_old.gif2014年6月27日01:10
[*]# 10
ChrisJ800
塔斯马尼亚电气、直升机、滑翔机
霍巴特,澳大利亚
2002年10月加入
2515个帖子
今天早上我只是maidened矿。视线飞行,没有设置我的AP / OSD或给予废票齿轮。传单伟大,不需要副翼,用鼠标点几下电梯的削减,这是好。发射很容易使用大举半油门没有浸渍的迹象当节流应用(不像我AXN)。所以V2电动机角度正确。
我用2200并行3 s包让它平衡但CG船尾。它实际上是一个中立的CG在68毫米(做45度的潜水测试)因此,手工很好,但我喜欢与CG触摸前方飞。我有足够的空间移动我的2包生产。像Arxangel问题提示停滞(fwd CG)我试着一些摊位,我并没有提示停滞的迹象,只是mushed慢慢停滞下来。我甚至试过失速而转,没有惊喜。
我试着襟翼和哇他们慢下来满拍打它归结非常快。我登陆是和半瓣,只是摔在地上,我没有能够爆发,因此需要减少下次襟翼的耀斑。我也做了一个高速俯冲/滑动没有汽车,这是一个令人愉快的吹口哨的声音,因为它过去的速度。电力与股票汽车/道具是足够的。它不是一个高性能的飞机,现在我将装载废票齿轮。我唯一的抱怨是它的一个大模型2米的翅膀和操纵翼是一个痛苦。对我好,我有一个足够大的车挤在操纵。
看上去不错!{:1_1:} {:1_12:}{:1_12:}{:1_12:} {:1_1:} 哈哈,英语复习资料~
