【大力电子】成功进过 9xII 的工程模式 (service menu) (新增9xI...
网上找到 JR 9303(9xII) x9303(DSX9) 的进service menu的方法,试多次都无法成功。
Accessing the X9303 and XP9303 Service Menu:
[*]Pull Throttle Hold switch into the forward position.
[*]Pull AILE D/R switch up.
[*]Power the set on while keeping ENT button on front panel pressed.
[*]Rotate roller activator until Trim Step is highlighted.
[*]Press roller activator on Trim Step, rotate to AILE.
[*]Switch AILE D/R down, press roller activator, switch AILE D/R up, press roller activator.
[*]Repeat Step 6 four more times and on the 5th (total) time access should be granted to the Service Menu.
Here is a list of things you can do - should be in order as you scroll through each item. This is not a complete list, and there are likely lots of other things that can be done.
[*]From here, SW test allows you to test each switch and microswitch.
[*]The next menu item is Hard. Con. By rotating the selector bar it becomes obvious what can be changed by soft selection. Where the highlighter does not move it indicates that this is a hard connection on the PCB, but in conjunction with the table this can be modified accordingly.
[*]Next item is Stick Neutral. Center all sticks and side trimmers, press CLR followed by STO. This then stores all the centers for the sticks.
[*]Next is Stick Ga. Moving all sticks and side trimmers to max & min positions finalizes the stick calibration.
[*]Moving the selector across to the right allows for setting front panel voltage, and at what voltage the alarm will activate for low battery.
There are various ways to exit, and each one has a different effect. Total reset of system and loss of models stored, reset of the config data only. For straight calibration purposes, rotate back to EXIT and press the button next to : Reset start (No Initialized)
http://www.rcgroups.com/forums/showthread.php?t=866144
经多次试验和与国外玩家讨论,终于成功试出9xII的service menu, 进入方法和控的stick mode有关系,上面的流程是stick mode 2的方法,对于我们购得的大部分是stick mode 1的控, 要使用 TRN 代替 TH.HOLD,其它相同 (在第6步前拉住TRN即可)
提示: 不懂的项目请别随便乱动,可能导至摇控不工作, 特别是重置工厂设置及RAM EDITOR功能, 错误的恢复工厂设置可能会丢失很多需要工厂校准的数据, 使用控不能正常工作, 必须返厂维修(重校准)
支持支持再支持 明天更快乐能在详细点吗 为了三千积分! 我擦!我要沙发! 我也是坐沙发的 传说中的沙发???哇卡卡
