【大力电子】Sanwa Exzes-Z 遥控器
Sanwa 推出 Exzes-Z 杆式(棍式)遥控器, 实际上是M12的杆式版本。拥有超高响应速度,实时更改设定曲线功能,内置遥感功能,可外接感应器量度转速、电压、温度等参数。新款Exzes-Z重量更轻,带 128×256 LCD 显示屏,设定界面也更人性化。http://rcfans-discuzx.b0.upaiyun.com/portal/201310/21/102839et3hno23q66jofu3.jpg新特性:• DMS Setting:Directly read your registered model at the launch
• TH 5:5 mode: TH neutral pulse 1.5m sec
• Point AUX: integrated maximum 6 points AUX
• MOA MIX : Respond to 2 motor throttle
• 4WS MIX: Respond to front and rear steering individually
• SPEED Setting: ST/TH point, direction setting available
• MODEL Sorts Setting: Model order can be sorted as you like
• Ch Set Menu Setting: Setting menu for every CH功能:
- Car type select: 10 categories
- Racing mode: able to change driving status in a single touch
- Data logger: data can be sent to the PC
- Monitoring: share data with another transmitter
- PC link: able to read and write the data to the PC
- Dual steering: able to set the rudder angle individually
- Best fit setting: Able to set the driver’s best condition
- Curve setting: able to fine adjust 9/18 point curve
- LCD display: 128×256 full dot LCD display
- Custom menu: user friendly menu structure
飞哥不错 蒙在股里不错 沈淼章顶你哈哈 沈淼章希望我们成为朋友 :lol :dizzy:
