沈淼章 发表于 2014-4-9 21:00:19
【大力电子】Futaba HS系列高速接收機
R6008HS 8-Channel Receiver
[*]Offers 2048 resolution plus FASST benefits including Dual Antenna Diversity and significantly reduced latency for lightning-quick response
[*]High-speed operation takes advantage of digital servos’ ability to update more rapidly than analog servos (both can be used with this receiver)
[*]HS (High Speed) mode improves frame rate on channels 1-6 to only 7 milliseconds — compared to 14 milliseconds at normal mode.** Note: In HS mode, digital servos (including those in the BLS series) must be used on channels 1-6. Those channels will also operate gyros and brushless ESCs. Channels 7 and 8 continue at normal mode and accept any servos.
Stock #DimensionsWeight
FUTL76391.8 x 0.9 x 0.5 in (45 x 22 x 13 mm)0.48 oz (13.54 g)
http://www.rcmania.hk/data/attachment/forum/201203/22/17031371vhgoavoq71mcm9.jpg
R6014FS Receiver
[*]True, 14-channel design.
[*]Designed specifically for FASST™ 2.4GHz systems.
[*]Push-button Easy-Link™ feature locks receiver to the transmitter’s unique signal.
[*]Includes battery fail-safe with auto cut-off and setup LED.
FUTL76451.5 x 2.1 x 0.6 in (38 x 52 x 16 mm)0.76 oz (21.5 g)
http://www.rcmania.hk/upload/a/images/08/img151250277325.jpg
gopro 发表于 2014-4-10 06:34:22
gopro学习了
蒙在股里 发表于 2014-4-10 06:34:36
蒙在股里能多点图片吗
爱飞 发表于 2014-4-11 00:59:51
爱飞帮顶
老刘的烦恼 发表于 2014-4-11 01:02:42
老刘的烦恼能在详细点吗
李俊 发表于 2014-4-11 21:31:56
;P
明天更快乐 发表于 2014-4-11 21:32:08
沈淼章谢谢分享
活着的死人 发表于 2014-4-12 14:56:22
小宇宙 发表于 2014-4-12 14:57:32
沈淼章谢谢分享
查看完整版本: 【大力电子】Futaba HS系列高速接收機
