983查看 | 9回复
大家手中的X9D+都用的什么固件
发表于 2018-9-1 11:32:38 | 显示全部楼层 |阅读模式
是用OPEN TX官网的2.2.2(2018-7-28)
还是用睿思凯官网的2.2.2(2018-5-25)
发表于 2018-9-1 11:49:33 | 显示全部楼层
我用的是官网的
发表于 2018-9-1 12:09:40 | 显示全部楼层
这种开源控。不刷第三方固件就是浪费吧
发表于 2018-9-1 12:34:17 | 显示全部楼层
这个好用吗
发表于 2018-9-1 15:01:43 | 显示全部楼层
当然下OPENTX官网的
发表于 2018-9-1 19:54:24 | 显示全部楼层
发表于 2018-9-2 17:32:47 | 显示全部楼层
opentx官网
发表于 2018-9-4 11:52:45 | 显示全部楼层
opentx官方下载页面说了,用睿思凯遥控器的,要去睿思凯下载,因为睿思凯是定制版本。
以下是opentx官网原文:
For Taranis users
Please note that your radio has been delivered with a firmware that is customised and exclusive to FrSky, and is not part of the OpenTX team’s offerings and development cycle. It is supposed to be used on its own, exclusively on the radio (no companion), and is supported directly by FrSky which means that should something not work or any feature request should be expressed directly to them. It is stable and suitable for most usage cases, and is the preferred version that most Taranis owners should likely be using.
Switching to the OpenTX team’s releases and using tools like companion should be considered an “advanced” usage scenario that will require some computer knowledge, a bunch of reading to find out about the differences and may cause headaches if things don’t go as expected. Be sure to read the paragraph below about how OpenTX versioning works, and to always use matching combinations of companion and firmware.
The Taranis X9D comes with a version derived from OpenTX 1.0
Taranis X9D+ comes with a version derived from OpenTX 2.0
Taranis X9E comes with a version derived from OpenTX 2.1
Taranis Q X7 comes with a version derived from OpenTX 2.2
If you want to switch your firmware to OpenTX and keep the known behavior you should stick to those major versions.
The Taranis Plus will not work with OpenTX versions older than 2.0.10
Taranis X9E will not work with OpenTX versions older than 2.1.0.
The FrSKY Horus X12S and Taranis Q X7 will not work with OpenTX versions older than 2.2.
用Google翻译了一下:
对于Taranis用户
请注意,您的遥控器已经交付了固件,该固件是专为FrSky定制的,并且不属于OpenTX团队的产品和开发周期。它应该单独使用,专门用于遥控器(无伴侣),并由FrSky直接支持,这意味着如果某些内容不起作用或任何功能请求应直接联系他们。它稳定且适用于大多数使用情况,是大多数Taranis所有者应该使用的首选版本。
切换到OpenTX团队的版本并使用像companion这样的工具应被视为一种“高级”使用场景,需要一些计算机知识,一堆阅读才能找出差异,如果事情没有按预期进行,可能会引起麻烦。请务必阅读以下有关OpenTX版本控制如何工作的段落,并始终使用配套和固件的匹配组合。
  • Taranis X9D附带一个源自OpenTX 1.0的版本
  • Taranis X9D +附带一个源自OpenTX 2.0的版本
  • Taranis X9E附带一个源自OpenTX 2.1的版本
  • Taranis Q X7附带一个源自OpenTX 2.2的版本
如果您想将固件切换到OpenTX并保持已知行为,您应该坚持使用这些主要版本。
  • Taranis Plus不适用于早于2.0.10的OpenTX版本
  • Taranis X9E不适用于早于2.1.0的OpenTX版本。
  • FrSKY Horus X12S和Taranis Q X7不适用于早于2.2的OpenTX版本。
发表于 2018-9-4 22:11:38 | 显示全部楼层
marsyuming 发表于 2018-9-4 11:52
官网下载页面说了,用睿思凯遥控器的,要去睿思凯官网下载,因为官网是定制版本。
以下是官网原文:
我X7刷了openTX的2.2.2。openTX更新比官方勤快多了啊
发表于 2018-9-4 23:38:45 | 显示全部楼层
对,opentx官方说了,frsky出的固件是官方定制,最稳定版本。几乎所有系统的稳定版本,比如电脑系统、手机固件,更新的都很慢。主要是为了稳定不出问题。
