沈淼章 发表于 2014-2-5 14:58:48
【转kk】发动机空气冷却道的要点
很有参考价值,帖子来自www.5irc.com如何讓引擎達到有效的冷卻效果
如何讓引擎達到有效的冷卻效果
http://5irc.com/data/attachment/forum/201311/24/113302bkrk2v4ok9k7n9rb.jpg
http://5irc.com/data/attachment/forum/201311/24/113302i2ciahuxvp9gigi9.jpg
http://5irc.com/data/attachment/forum/201311/24/113304f311j86vbovzg3fb.jpg
http://5irc.com/data/attachment/forum/201311/24/113307jtmb3bw6u63wqzf2.jpghttp://5irc.com/data/attachment/forum/201311/24/113306ecbpxvqrkxquuctc.jpg
http://5irc.com/data/attachment/forum/201311/24/113306ympo7sayq71pnam7.jpg
http://5irc.com/data/attachment/forum/201311/24/113305u7ameutzklukfmnt.jpg
http://5irc.com/data/attachment/forum/201311/24/113304ohizr6p4pwtynjpq.jpg
Peter Folmer, who at first sent me in an engine with severe overheating symtoms, gave me permission to publish his data and experience, so others might benefit.
Here goes:
Repair engine, run in "normal glow engine fashion with cowled engine" in a 3D airplane.
The cylinder had turned all shades of yellow. purple, blue and gray, indicating engine temperatures in excess of 300°C. Piston and cylinder were OK, but crankshaft, conrod and all bearings needed to be replaced.
The cylinder head anodize had lost a few shades of hue (color had bleached) due to the heat.
以上是飛友在描述引擎發生嚴重過熱的情況
還有發生過熱引擎出現的變化
這顆引擎高溫達到高溫達到300度
內部機件都已損壞!!該換都換了
其他就沒太多的重點
以下就是重點了
After repairs, he installed a Venom temperature gage, and these are the results:
這是未安裝導風版引擎溫度的狀態
No cowl:
prop 18x6, rpm 9000 static, max temp. 132°C (static and 3D)
prop 16x12, 8000 rpm static, max temp 118°C (Aerobatics)
這是使用導風版後的情況
Peter then prepared baffling and a cylinder jacket made from aluminium air ducts. For air extraction from the cowl, louvres were made, and they proved very effective.
In flight: max temperature of 95°C (outside air was at 10°C, so quite cool)
ground running: max temp 100°C
Ground running, changing from 1/2 to 1/1 throttle vice versa, the temperature rose to 85 degrees. when the engine returned to idle, the temp. dropped very quickly to 69°C
For Images of his setup, see next post (soon)
大家也一起來分享您是如何讓引擎達到散熱的方法
以上文章來自PRME Engines User Community Forum
http://5irc.com/data/attachment/forum/201311/24/113301szhp85rp8hhjv8zs.jpg
http://5irc.com/data/attachment/forum/201311/24/113819ue7abdw7waau35ua.jpg
http://5irc.com/data/attachment/forum/201311/24/113821zlnxa66q4bqan7vp.jpg
http://5irc.com/data/attachment/forum/201311/24/1138217c85c87bb14ct274.jpg
http://5irc.com/data/attachment/forum/201311/24/113818h6wsbe61uvh5h3vc.jpg
沈淼章 发表于 2014-2-5 14:59:40
http://5irc.com/data/attachment/forum/201311/24/1552199lr0h8rf2heh2uf9.jpg
http://5irc.com/data/attachment/forum/201311/24/1552212g0em1ps4mpgbg0k.jpg
完了加快进气道空气的速度 增加了导流板。
沈淼章 发表于 2014-2-5 15:00:13
http://5irc.com/data/attachment/forum/201311/24/161753kqw1v3zkweixvccd.jpg
http://5irc.com/data/attachment/forum/201311/24/1618021esoobbaobrr10eo.jpg
http://5irc.com/data/attachment/forum/201311/24/161759jqeetiorirrazw42.jpghttp://5irc.com/data/attachment/forum/201311/24/161758glbmv84b7e9kkbgk.jpg
http://5irc.com/data/attachment/forum/201311/24/161757mno6lnkphng8nkmt.jpg
http://5irc.com/data/attachment/forum/201311/24/161756zy8djdtzj9hf88d9.jpg
http://5irc.com/data/attachment/forum/201311/24/161754yttduedteujdtj6j.jpg
刚买的遥控技术上的介绍分享一下。
http://5irc.com/data/attachment/forum/201311/24/161800tqvse62y2sw3sfwe.jpg
刚买的遥控技术上的介绍分享一下。
沈淼章 发表于 2014-2-5 15:00:56
原帖翻拍的杂志
http://5irc.com/data/attachment/forum/201311/25/1042195gafoqoosly54fs2.jpg
http://5irc.com/data/attachment/forum/201311/25/104221b0gi3gby8hz665i7.jpg
http://5irc.com/data/attachment/forum/201311/25/104223u50tinxbix7j3jtt.jpg
http://5irc.com/data/attachment/forum/201311/25/104224r175ndd1g7dkn8wf.jpg
http://5irc.com/data/attachment/forum/201311/25/1042251np4527b5p46n2eg.jpg
http://5irc.com/data/attachment/forum/201311/25/104227f9dmzn0nvdzdn0gd.jpg
http://5irc.com/data/attachment/forum/201311/25/1042290ht4hmhzv4e4tztg.jpg
http://5irc.com/data/attachment/forum/201311/25/104230ezmudld2byzruubn.jpg
查看完整版本: 【转kk】发动机空气冷却道的要点
