请模友们帮我看看
玩四轴有好几年了,就想自己diy个悟,只为装逼,买了3d打印机,打印了全部零件,关键卡在了变形部分,用了arduino nano和行程开关控制舵机,程序是我网上找的,我感觉程序里定义的引脚和连接图不一样(实物连接图在下面)自己搞了好久还不行,请模友们帮我看看。不胜感激 最下面是程序。// Designed for Skull Quadcopter
// Rev 1.0
#include <Servo.h>
#include <PinChangeInt.h>
// Define RX variables
#define PIN1 2
#define PIN1dataReg PIND
#define pin1state (PIN1dataReg & (1 << PIN1))
volatile long pulseStart1; // pulse start time measured from millies in ISR for pin 1
volatile long pulseTime1; // pulse width time measured from millies in ISR for pin 1 <-- this is the output we require
Servo myservo;// create servo object to control a servo
int pos = 0; // variable to store the servo position
// Define Microswitch pins
const int msdown = 5;
const int msup = 4;
int msdownstate = 0;
int msupstate = 0;
// Define Variables for LEDs
int led1 = 6; // output pin for LED 1
int led2 = 7; // output pin for LED 2
int led3 = 8; // output pin for LED 3
int led4 = 9; // output pin for LED 4
int led13 = 13; // onboard LED indictor incase no others are attached
unsigned long time; // holds current time for change of state
int flashtime = 400; // time to flash LEDs in milliseconds
boolean ledon = false; // remembers start of LED
boolean movedown = true; // safety feature
boolean moveup = true; // safety feature
// The below procedure handles the pulse from the RX input
void handlePin1()
if(pin1state)
pulseStart1=micros(); // we got a positive edge
else
pulseTime1=micros()-pulseStart1; // Negative edge: get pulsewidth
// LED Control - very basic, can be expanded.
void turnledoff() {
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
digitalWrite(led13, LOW);
void turnledon() {
digitalWrite(led1, HIGH);
digitalWrite(led2, HIGH);
digitalWrite(led3, HIGH);
digitalWrite(led4, HIGH);
digitalWrite(led13, HIGH);
void flashled() {
// LED Flash
if (millis() - time > flashtime){
time = millis();
if (ledon){
turnledoff();
ledon = false;
} else {
turnledon();
ledon = true;
// Lets set everything up
void setup() {
// initialize serial communication at 115200 bits per second so we can see whats going on:
Serial.begin(115200);
pinMode(PIN1, INPUT); // Initialize rx input pin
digitalWrite(PIN1, HIGH); // Set the rx pin to High to start the counter
PCintPort::attachInterrupt(PIN1, &handlePin1, CHANGE); // Attach the interrupt
pinMode(led1, OUTPUT); // Assign output mode to pin for LED 1
pinMode(led2, OUTPUT); // Assign output mode to pin for LED 2
pinMode(led3, OUTPUT); // Assign output mode to pin for LED 3
pinMode(led4, OUTPUT); // Assign output mode to pin for LED 4
pinMode(led13, OUTPUT); // Assign output mode to pin for LED 4
pinMode(msup, INPUT);
pinMode(msdown, INPUT);
msupstate = digitalRead(msup);
msdownstate = digitalRead(msdown);
time = millis(); // Save current millis reading (this is a counter that always runs in milliseconds)
turnledon();
// Main Program
void loop() {
// read the input channels
if (pulseTime1 > 900 && pulseTime1 < 1300){ //legs down
myservo.attach(3);
pos = 0;
moveup = true;
if (msupstate == LOW){
if (movedown){myservo.write(pos);}
flashtime = 200;
flashled();
} else {
movedown = false;
myservo.detach();
turnledon();
if (pulseTime1 > 1299 && pulseTime1 < 1701){ //no movement
myservo.detach();
pos = 100;
if (pulseTime1 > 1700) { //legs up
myservo.attach(3);
pos = 180;
movedown = true;
if (msdownstate == LOW){
if (moveup) {myservo.write(pos);}
flashtime = 200;
flashled();
} else {
moveup = false;
turnledon();
myservo.detach();
顶楼主
不懂帮顶
顶http://www.moz8.com//mobcent//app/data/phiz/default/04.png
帮顶 像我这种专业白学的,连看都看不懂
都是高手赞
顶一下,高手高手高高手
只做上下限位的话,用二极管和常闭开关改舵机就行,没必要这么复杂。
表示已经飞起来了。。
小丑人生 发表于 2018-7-12 22:59 static/image/common/back.gif
哥们,具体的连接图有吗?还想控制四个灯
你找的这个写程序的人自己有没有成功呀,arduino 的舵机只能接9,10口,你的在3口
https://zhidao.baidu.com/question/354346468.html madanzi 发表于 2018-7-13 11:06 static/image/common/back.gif
https://zhidao.baidu.co ...
别人不知道有没有成功,我也发现程序里定义3脚,回去改下看看
路过。
不懂帮顶
虽然看不懂,但是赞一个
小丑人生 发表于 2018-7-12 23:00 static/image/common/back.gif
表示已经飞起来了。。
这个厉害
表示已经飞起来了。。
厉害了
