4272查看 | 19回复
FT-3D机配置解读(参数篇)
发表于 2014-1-7 16:28:59 | 显示全部楼层 |阅读模式
有模友看了本人发的帖子:入魔首选3DKT机
http://www.moz8.com/thread-14278-1-1.html?x=6404
问配置情况
现发帖给出列表和一些设备的详细参数,想了解的模友也可查看参考了。
主要设备列表(设备多为国外品牌,仅供参考,使用相近参数的设备即可):
视频中使用的设备:
电机:NTM Prop Drive Series 28-26A 1200kv / 250w
舵机:Hextronic 9 Gram Servo
电调:TURNIGY Plush 25amp Speed Controller
电机座:FT Firewall
舵角:FT Control horns
连杆:1 mm piano wire (push rods)/0.81 mm piano wire
电池:Turnigy 1300mAh 3S 25C Lipo Pack
连杆快速调节器:Linkage Stopper "Speed Clevis"
遥控器:Futaba T8FG Super 14ch Transmitter w/R6208SB 2.4GHz Receiver
接收机:Futaba R6106HFC 2.4GHz FASST Mid Range 6Ch Rx
可选配置:
电机:Suppo 2208/14 1450kv Brushless Motor (Park 370 equiv.)
螺旋桨:APC-style Electric Propeller - 8x4E
电调:Suppo 18A Brushless ESC
舵机:Suppo SP-90 9g Micro Servo
附原外文列表
Equipment used in this build:
FT Firewall
FT Control horns  1 mm piano wire (push rods)
Additional/Alternate components:
一、电机参数
1、NTM Prop Drive Series 28-26A 1200kv / 250w
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 2886
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 469
Kv :  1200 RPM/V
Weight :  53.6 g
Max Current :  18 A
Max Voltage :  15 V
Power  : 250 W
Internal resistance :  ?
Shaft (A) :  ?
Length (B) :  26 mm
Diameter (C)  : 28 mm
Can Length (D)  : 15 mm
Total Length (E)  : 29 mm
Model: NTM Prop Drive Series 28-26A 1200kv (short shaft version)
Kv: 1200rpm/v
Max current: 17A
Max Power: 215W @ 12v (3S) / 286W @ 15v (4S)
Shaft: 3mm
Weight: 57.6g
ESC: 20A
Cell count: 3s~4s Lipoly
Bolt holes: 16mm & 19mm
Bolt thread: M3
Connection: 3.5mm Bullet-connector
Prop Tests:
7x6E - 11.1v - 90W - 8A
7x6E - 14.8v - 192W - 13A
8x4E - 11.1v - 100W - 9A
8x4E - 14.8v - 222W - 15A
8x6E - 11.1v - 145w - 13A
2、Suppo 2208/14 (28-26) 1450kv Specifications:
•Number of Cells: 2-3s lipo; 6-8 cell NiMh
•Max Efficiency Current: 5-9A (>74%)
•No Load Current (10v): .6A
•Max Current: 12A/60s
•Max Efficiency: 80%
•Internal Resistance: 140mΩ
•Shaft Size: 3.17mm
•Poles: 14
•Max Watts: 130w
•Weight: 36g
•Dimensions: 27.5x26 (mm)
•Minimum Recommended ESC: 18A
•Recommended Model Weight: 200-500g
二、电机座:
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 4737
三、舵角:
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 3774
四、舵机:Hextronic 9 Gram Servo
Size : 21x12x22 mm / 0.74x0.42x0.78 in
Voltage : 3v ~ 6v
Weight: 9g / 0.32oz
Speed : 0.12 sec/60(4.8V)
Torque : 1.6 kg-cm
Working Temp : -30C~60C
五、电调:TURNIGY Plush 25amp Speed Controller
Cont Current: 25A
Burst Current: 35A
BEC Mode: Linear
BEC : 5v / 2A
Lipo Cells: 2-4
NiMH : 5-12
Weight: 22g
Supported motor speed for all TURNIGY ESCs is;
(Maximum): 210000 RPM (2 poles), 70000 RPM (6 poles), 35000 RPM (12 poles).
以大部分是国外的部件,贴出参数可以更好地为模友在国内选购类似部件提供参考。
发表于 2014-1-7 16:49:36 | 显示全部楼层
这电机看起来很带感
发表于 2014-1-7 17:41:52 | 显示全部楼层
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:wwh99 5623 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:wwh99 3707 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:wwh99 5096
发表于 2014-1-7 19:04:00 | 显示全部楼层
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:wengchuankuo 9096 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:wengchuankuo 4653 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:wengchuankuo 7474 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:wengchuankuo 8269
发表于 2014-1-8 08:33:52 | 显示全部楼层
NTM电机……怕怕! 做功一般,轴芯不行!
来自安卓客户端
发表于 2014-1-8 18:23:02 | 显示全部楼层
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:狂情怒放 4926
 楼主| 发表于 2014-1-9 22:53:35 | 显示全部楼层
Stevenkwok 发表于 2014-1-8 08:33 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 6990
来自安卓客户端
愿闻其详,
发表于 2014-1-9 23:11:32 | 显示全部楼层
Marshal发表于2014-01-09 22:53:35 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Stevenkwok 7911
愿闻其详,
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Stevenkwok 1418 飞了一次的ntm[晕]
来自安卓客户端
发表于 2014-1-9 23:13:15 | 显示全部楼层
正常landing 幔速落草地便完了
来自安卓客户端
发表于 2014-1-9 23:14:25 | 显示全部楼层
手上還有兩个也不再用了,或可考慮用在腰推机上
来自安卓客户端
发表于 2014-1-9 23:15:01 | 显示全部楼层
我用朗宇双天好多了!
来自安卓客户端
 楼主| 发表于 2014-1-10 11:07:02 | 显示全部楼层
Stevenkwok 发表于 2014-1-9 23:11 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 4132
飞了一次的ntm[晕]
来自安卓客户端
看样子,是不是轴都掉出来了?要真是这样的话,那质量不行哦。
 楼主| 发表于 2014-1-10 11:08:19 | 显示全部楼层
Stevenkwok 发表于 2014-1-9 23:15 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 7361
我用朗宇双天好多了!
来自安卓客户端
朗宇,双天有没有类似参数的推荐一下
 楼主| 发表于 2014-1-10 11:09:12 | 显示全部楼层
Stevenkwok 发表于 2014-1-9 23:14 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 9676
来自安卓客户端
表示同情
发表于 2014-1-10 12:00:21 | 显示全部楼层
Marshal发表于2014-01-10 11:09:12 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Stevenkwok 6907
表示同情
感覺是轴芯及轴承質量不行,外国rcgroups也有讨論過
来自安卓客户端
 楼主| 发表于 2014-1-10 14:39:04 | 显示全部楼层
Stevenkwok 发表于 2014-1-10 12:00 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 6677
来自安卓客户端
好,谢谢,那我只能按参数选购了
发表于 2014-1-11 22:36:17 | 显示全部楼层
国外找的资料,我说全是英文,英语学的不好看不懂
 楼主| 发表于 2014-1-13 22:25:00 | 显示全部楼层
lylong 发表于 2014-1-11 22:36 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:Marshal 2206
翻译一下就懂了,看多了也就懂了,
发表于 2014-5-14 14:08:46 | 显示全部楼层
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:@FENG@ 2896 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:@FENG@ 5730
发表于 2016-9-9 10:56:32 | 显示全部楼层
FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:天山一棵松 6338 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:天山一棵松 9204 FT-3D机配置解读(参数篇) 电池,舵机,电调,电机,遥控器 作者:天山一棵松 3391
